Power feeders
Power feeders
Power feeders
GarryVA
>Any recommendations on make & size of a power feeder to use with a shaper?
Re: Power feeders
Rick L
Re: Depends...
Rick L
>I hp, three wheel is the most common set up for 3 hp and up. More info on your shaper size, power, and projected use will give more targeted answers. I find most questions do not have enough info. Hobby, pro, occasional use, daily? As far as brand, Maggi is one of the top brands and makes most of the feeders under many different names, particularly the European brands. On a budget, Sunhill, Bridgewood, Grizzly will work fine. Delta, PM are importing some other brand so would not be considered name brand units.
Re: Power feeders
That Describes Each Of My Sevden Sons
Re: Power feeders
Re: Power feeders
JRutter
>What Rick said - depends. I started out with a 1/2 HP Grizzly on my first shaper. I still use it and it works fine. It isn't as heavy as the 1 HP, but handles everything that you would do on most shapers. The Maggi 2034 that I have is almost identical to the Comatic but is built better in subtle ways. If you have cutters that run in different directions, then a 4-wheel is easier to pivot back and forth, keeping the spindle between the 2 middle tires.
