>I have a relatively new custom painted wood hood above our range in our kitchen. It's only been in for a year and it already has a small hariline fracture in one location right at the center that's about 1/2" to 3/4" long. Is there a way to repair this?
>... you can almost always repair something, at least cosmetically. My hunch is that this isn't a structural repair, so some filler and touc-up should make it invisible. The way this is done in the business is to fill the crack with some water-based wood putty, removing as much of the excess as possible with your putty knife. If the surrounding wood has open pores, you might want to mask the area with masking tape to keep the filler out of the pores.
Next you need to smooth the patch. I would recommend using fine Scotch-brite, rubbing just enough to remove any traces of excess filler. If necessary, sand *very* lightly with 320-grit sandpaper. (Once you do this, you are committing to renewing the wood finish, so only do it if you can't get the excess off in any other way.)
Grain painting is the way to make the patch disappear. The pros use very finely ground pigments and a tiny red sable touchup brush. Put a little bit of lacquer or shellac into a bottle cap. Dip the point of the brush into the lacquer and then into the pigment and paint it onto the patched area to match the surrounding wood. Presto.
