OT - Algae on my Vinyl Siding *LINK*
Rick VS
>Like most of my neighbors, I have vinyl siding. Unlike most, every year I get what I believe is algae forming on the north and east sides of my home. Every year I have to power wash it off. Is there something that I can do to prevent it from coming back each year, and why don't most of my neighbors have a similar problem? What am I doing wrong :-) Click on the link to see a picture of the problem. Any help would be appreciated. Thanks!
Rick
Algae Picture
Re: OT - Algae on my Vinyl Siding *LINK*
RE; Alge growing on siding
Dave Anderson (Pac NW)
>Looking at the picture, it appeares that the growth is coming from beneath the siding. this could be caused by lack of a moisture barrier on the inside wall. The water vapor goes through the wall and condenses on the back side of the siding and coming out of the weep holes. unless you live in the puget sound area. then everything grows alge over the winter
Just my 2 cents worth,
Dave Anderson
Re: OT - Algae on my vinyl siding
Al Stokka - Cambridge, Iowa
>Rick,
Algae will grow on siding that gets wet and dries slowly. I wish you had a wider-angle in the photo, but it looks like the algae is below a porch roof. Perhaps rain water rushes down that roof, splahes over the gutter and wets the siding? Another item: That yew, being so close to the wall, will limit air flow to the siding which will allow the siding to remain wet once it is wetted.
Check the water situation during the next rain. Prune the yew away from the siding to allow airflow.
Wash the siding with a stiff brush using warm water with a cup of chlorine bleach added to each gallon of water (you can add a detergent, too, if you want to).
I had the same problem on the north side of my house, so don't feel as though you're the only one.
Al
Rick VS
>Al,
The picture happens to be behind the tree, but there are vertical bands that cover the side of the garage and the entire front of the home, so I don't think it's a 'local' dampness issue caused by the tree or a rain gutter for example. I fail to see why most of my neigbors with the same siding don't have a problem. Maybe the builder was drinking the day he built it and did forget about the moisture barrier as Dave said. Thanks.
Ronald
>mix some bleach with water. about 1cup bleach to 3 gallon water in a pump sprayer. spray the siding and power it off. that will stop it for a year. but i grows on the shady side all the time. I have it to.
Doesn't a weak bleach solution kill it off?
SanMan
Don Evans
>Don't fret over this. You are not doing anything wrong and it's not likely water for sweat etc.
This is a very, very common problem with siding that is on the North side of a home.
It is directly related to fact that your house is shaded or another way of saying it, it just doesn't get enough wind and sun on that side of the house to keep it from happening.
Your neighbors that you mention, look and see if their north sides are more open and get some sun where yours in mostly in the shade all day.
I have same problem due to woods.
Don
Clorox For Outdoors
MaxM
>They sellit at HD or Lowes. A good soaking with a pressure washer gets alot of it off. You don't need to really blast the crap out of it. I soak the area with the bleach mixed with water, then run the pressure with plain water starting from the top down.
Comes out nice and sparkly!
