Door Patch Idea needed
Tom Norton
>I have a job that has a pockect door that I needed to reverse. The reason one side was stained and varnished but got severly damagaed by a dog scratching it. The other side is in good condition so it will work. The problem is the inset pull on the door face. I need to install some type of patch,because now it is at the wrong end of the door. I was thinking of even a decorative patch. But am not sure.
Any thoughts?
Re: Door Patch Idea needed
Depends...
>Aesthetics may be a concern for one thing, but it may also depend on whether this is a hollow core door or a solid core door (or a solid wood door, for that matter). If you want to completely disguise the old recess, you will need to make a patch of the same species and grain direction and then cut it in flush to the existing surface. You can do this, even on very thin door skin by carefully routing a recess around the area and making a patch with a mating step in it. Glue it in, fill and grain-paint the transitions and give it a coat of finish. If you have enough clearance in the pocket door opening for a raised patch, and you don't care if it is visible, just make a stepped patch of whatever suits you and glue it in.
Ellis Walentine, host
Then Again...
Craig in Silverdale
>Is it a smooth or a paneled door? is the latch in the middle of the door? Would it be possible to remove the rollers from the top and afix them to the bottom, turn the door upside and flip the latch 180. now you only have to fix the strike plate. This advise and 3 bucks will get you a small coffee at Starbucks. The definition of COFFEE is, the one being coughed upon.
DB
>If the door is a hollow core door. You could always go to your local lumber yard and get a new door skin in the correct wood. You may even be able to get a whole new door cheap enough to make a patch seem not worthwhile.
