Drawers
Brian A
>Just wonder what wood do you usually use for the sides and backs of drawers. Making a bathroom vanity.
Thanks
Brian
Drawers
Brian A
Thanks
Brian
Re: Drawers
Jack Guzman from Maine
>poplar or pine---Jack
Re: Drawers
Charles Sharp
>1/2" Baltic Birch
1/2" poplar
Lee Schierer, McKean, PA
>I use 1/2" poplar for all my drawer sides and 1/4" plywood for the bottoms. It is strong and easily worked. I also finish the drawers inside and out.
Lee
Re: Drawers
Brian A
>Is Batic Birch a plywood? Where do you find it? HD?
Brian
Yes
Mark McC
>In Canada anyway... HD or almost any good Lumber supply.
I prefer it to solid wood for drawers, mills nicely, stable.
Re: Drawers - thrifty female POV
Carol from AZ
>1/2" Baltic Birch ply sides/ends.
1/4" double sided Melamine bottoms.
Both available from good sheet goods supplier (used by cabinet shops), NEVER HD, etc.
Best yield, less preparatory work.
And no drawer liner need.
Shellac finish for no-stink forever drawers
Re: Drawers
Johanna
>I do not recommend HD or Lowes for BB plywood. Get if from a hardwood lumber company that supplies cabinet makers. It comes in 60" square sheets.
1/2" Baltic Birch Ply
Re: 1/2" Baltic Birch Ply - Joinery?
Eric
>This may be a stupid question ,but I'm curious, can you dovetail BB ply? I've got my first drawer project coming up and I'm just wondering.
Yes
David Yoho
Re: Drawers
Glenn Madsen near San Francisco
>Baltic birch is almost like a class of goods these days. Should be an excellent quality, void free plywood, like the Finns do/used to produce.
North American producers also make the stuff, in 4x8 to 4x12 and more sheets. For drawers for kitchens and baths, my supplier sells prefinished ply in 1/2" and 3/4", and also 4" and 12" widths, with eased, finished edges. Makes drawer building a lot faster and quicker. Very seldom would you find such products at the home center, but there are a lot of places where a cash buyer can bring some home. Check the yellow pages, or ask a cabinet shop where they source their supply.
Re: But you don't have to
>Almost any joinery will do. I often use #0 biscuits and a couple of panhead screws, and get it done quickly and square.
I do box joints with it....
John in New Mexico
>more for looks than strength. No need for anything other than screws if its running on ball bearing guides.
John
Doc Jim Follette...Fayetteville, NY
>I just made a bunch of drawers out of prefinished birch ply joining the sides to the front with dovetails. A couple observations: there is some delamination of the tails but it is not a problem because it occurs on what will be inside the joint. Make sure to score the sides at the lower extent of the cut to prevent chipping that can be seen inside the drawer. The sides, back and inside of the front can be eased after construction with a 1/4 round bit for a nice appearance.
Re: 2nd on the Prefinished
JackLane
>I'll second Glenn's recommendation on the prefinished birch plywood. In my cabinet shop I offer shop made maple or poplar dovetail drawers (3/4"), outsourced 1/2" Baltic birch dovetailed drawers and shop made drawers from the prefinished birch; My customers pick the prefinished birch 90% of the time.
Most of the lumber suppliers offer a prefinished edgbanding that matches the plywood also. This plywood makes beautiful drawers when you pocket screw from the fronts/backs into the sides. No fasteners visible. Good luck!
Jack
Re: Yes
Charles Sharp
>Rabbets and dado's with glue work just fine. Add a few finish nails to save time and clamps. Cut the bottoms out of sheet stock about 1/16" shy of actual groove dim. and it keeps everything square.
