Saw blade washers.
Rick in Colgate, Wi
>Anyone know where I can buy some machined saw blade washers for my table saw? I want to replace the cheap stamped one I now have.
Thanks!
Rick
Saw blade washers.
Rick in Colgate, Wi
Thanks!
Rick
Re: Saw blade washers.
Grant Smith
>Rick,
Suggest you check out the parts section of Deltas web site in the DeWalt Servicenet section (you'll have to sign up for access). Choose a saw similar to yours with the same arbor size and you should be able to order the washers you need.
If you need more help, let us know the model # of your saw and we should be able to be more specific.
Regards,
Grant in iowa
What saw do you have? *LINK*
Hoa Dinh
>Delta has a "Delta Arbor Nut Assembly." IMHO, it's the best $20 TS accessory.
The link below is for a RT saw. The nut assembly for LT saw does exist, but I can't find the link.
Rick in Colgate, Wi
>Thanks guys, I'll check out Delta, although I have a craftsman professional model saw.
Rick
