The pros know...
Jason Roehl in Mulberry, IN
>I've been in a number of houses where the trim was painted, but not caulked to the wall. Looked like crap. To do it right and good, both the walls and the trim will have to be painted after the trim is installed and caulked.
Our painting process for new homes (assume vacuuming/cleaning):
-mask windows
-spray and backroll primer on walls
-sand walls
-spray 1st color coat in all corners, including upper corners
-spray/roll 1st color coat, making sure all corners are now fully covered
-mask walls in upper corners
-spray ceilings
(...trim installed...)
-spackle/sand/caulk trim
-remove all doors and stand in room centers tacked together at top in zig-zag manner
-mask off anything that doesn't get painted (cabinets, floors, windows, etc.)
-spray all trim and doors with 2 topcoats (prime first if not factory-primed)
-re-paint walls, sometimes we tape the trim off first and spray the cut (twice), sometimes not.
-touch-up after carpet-layers (they ALL do at least SOME damage...)
Once you're good at using a masker, this is a very efficient process for a very good finish everywhere.
Jason (Addy protocol: pro painter)
