Fine Woodworking Article Question
Rick VS
>In the March/April issue, page 82, there are plans for a jig to enable you to shoot accurate miters with a hand plane. Here's my question for those that have the article handy: the jig's surface is exactly 45 degrees enabling you to 'shoot' the angle accurately. However, if the plane rides on the surface of the jig, won't the blade cut into the jig? And if the plane only rides on the surface of the workpiece, it won't be able to true the angle, say from 46 degress to the desired 45 degrees. Why bother with an accurate reference surface of 45 degrees if you can't leverage it to plane a correct angle of 45 degress? Help me understand the mystery . . . Thanks.
Rick
Re: Fine Woodworking Article Question
Ed Mulligan, Cape Cod
>Rick -
You must use a bench plane (#4, #5 ....) or similar plane where the iron does not extend across the full width of the sole. The iron does cut into the jig a few thousands of an inch but the small area where there is no iron acts as a depth stop and prevents further cutting.
If you used a rabbet plane or shoulder plane which has a full-width iron it would act as you describe and be effectively useless.
Ed
Rick VS
>Thanks Ed. So there is some cutting into the jig. That makes sense. Thanks again.
Rick
Robert Hutchins
>Howdy Rick,
Go over to the quiet side and search for a shooting board. There have been quite a few threads over the years. Might even be something in Articles or Shop Shots.
