Motor Guru needed
Motor Guru needed
Motor Guru needed
Doug_Rice
>OK guys, I know this is really reaching, but I am constantly amazed at the arcane expertise out there.
I have a dishwasher motor that I want to use to power a mandrel with a felt wheel, etc. I gather that the motor reverses (one way to spray, the other to drain.) There are four wires coming out of the motor, and labeled as follows on the schematic:
(1) "Main", connects to a relay
(2) "Drain" winding
(3) "Wash" winding
(4) Unlabeled, but has an overload protector shown on schematic
I assume (1) should be line in, and (2) neutral. Is that correct? Do I need to connect (1) with one of the other windings? Is there an easy way to use windings (2) and (3) to make a reversing switch for the mandrel?
Thanks to any moto-genius out there who can help.
Doug Rice
Kansas City
Re: Motor Guru needed
Bill Howatt
>Had a look at the wiring diagram that came with my Sears. I would say your assumptions are wrong.
The motor shows 3 windings, main, wash phase, drain phase.
The main connects to the motor start relay coil. The relay coil is in series with the Main winding. The timer applies power to the coil and main winding. This also pulls in a contact that applies power to "other switches" on the timer.
The wash phase wire connects to the switched side of one of the "other switches".
The Drain phase wire connects to the switched sider of a different one of the "other switches".
The other wire (White in my case) is the common (neutral).
So it seems that when the motor is running the main winding is energized with either the wash or drain phase energized.
You'll have to fire it up and see what happens. I would say it is not too likely to have a lot of power.
HTH,
Bill
Doug_Rice
>Thanks Bill. I really appreciate your advice.
Doug
>The motor does not reverse while in the DW. It just runs a pump. The pump either re-circulates the water through the spray heads or sends it down the drain, depending on what those "other switches" are doing. Solenoids either send the water back through the DW or down the drain. Give it a try.
Doug_Rice
>I don't know why I didn't think to scan the schematic on my first post, but here it is. On the time schedule either the spray winding or the drain winding is used, but not both at once. From Bill and Barry's comments it looks like the motor has two speeds. I assume the spray would run faster than the pump. I will hook it up today and play with it.
Bill and Barry, thanks for your help.
Doug
