OT: Metal paint cans
Ted Wong
>I've about had it with the traditional metal paint can. With the innovations in packaging over the last few decades why haven't paint manufacturers switched their packaging?
Today was the last straw. I had a can of premium ceiling paint that was 3/4 full. After prying the lid open I howled when I saw all the little chunks of rust that had fallen in as I was prying the top off. It isn't the first time this has happened and it isn't the only hassle I've had with cans. The pool of paint in the rim that needs to be wiped out after each pour is always a pita and drips running down the side after a pour is another pet peeve.
I've seen other manufacturers are now offering plastic containers with EZ pour spouts. why can't there be a new standard?
Re: OT: Metal paint cans
LOL, job security !
s.mackay@worldnet.att.net
It's too late for that can but...
Neal in San Jose
>When you seal up the paint at the end of the job, put a sheet of wax paper between the lid and the can. It helps to keep rust from forming in the first place by making a better seal, and keeps the rust out of the paint if it does form. My problem is remembering which flavor of off-white I used the last time. I usually have a dozen or so partially used cans in the garage to choose from!
transfer to a new can..
Norman (Ottawa, Ont.)
>I just had that very same problem over the weekend.
I was looking for some touch up paint from the paint we
had left over when we built our home.
Rust under the lid, and it flakes.The paint can looked fine otherwise.
I found out you can buy new empty paint cans at any paint
supply store , also Home Depot carries them.
So I will transfer the remainder into a new can when I get out to buy
it this week.
This time I'll wipe the lip of the top with vaseline to make a more moisture resistant seal.
Norman
Paint cans HAVE changed alot
>The first 1 gallon cans of paint that I bought when I purchased this house 10 years ago were all metal.
A couple of years ago, I noticed that they no longer make metal paint cans, now all the 1-gallon paint cans are black plastic and have teflon coated tin tops. No more rusting, no more stuck lids.
Progress.
But you're right, they only solved some of the problems. Not all of them. So close, but yet so far.
A couploe fo years ago Rubbermaid won an engineering advancement of the year award. They invented a Rubbermaid type container that you use to store your left over latex wall paint and it keeps it from drying ouut, plus it has a built in touch up brush/sponge, so you can touch up the nicks and scratches in your wall with the original paint.
I figure if we can use electromagentic techniques to power coat metal instead of using solvent based paints, why do we still use latex paint in those cans that you so properly described as old fashioned.
I believe we should follow Mr.Bean's lead and paint rooms the way he paints rooms. let me know if you DON'T know what I mean by this ;)
Happy Woodworking!
Saran Wrap Works, Too.
Robert Hutchins
>If you carefully place it on top of the liquid, it also retards the 'skim' formation, as well as keeping the rust out.
Maybe in your area...
Jason Roehl in Mulberry, IN
>...but I use LOTS of metal paint cans, day in, day out. Quarts, ones and fives, okay, not so much on the metal fivers--those are for solvent based finishes, of which I don't use much. But I buy paint in metal gallon cans all the time--and they're definitely metal, because the bottoms can still rust out if they sit too long.
Filter out the rust chunks, and the paint should be fine. When I pour from a gallon can, I just wipe the rim with either my brush or the roller (wet roller doesn't work so well, with a brush it doesn't matter). The little bit of paint left on the rim helps prevent rust and helps form a tight seal. Some guys keep a rubber mallet around to close them, but I just put some weight on my thumbs and am able to fully seat the lid. It helps if you pour quickly--less goes down the side of the can, then.
I often use my 5-in-1 to cut the rims out of the empties and then use them for cut buckets. They all get a nice rusty patina on the outside eventually. I've never seen plastic rust.
Jason
David Hay @ Denver
>One trick I learned, which helps a little, is to punch some holes with a screwdriver or nail set in the bottom of the rim around the top. This allows any paint that ends up there to drain back into the can, but doesn't affect the seal of the lid.
I've also found that the little plastic spouts that clip on to the rim of the can are also great for drip-resistant pouring.
Of course, none of this would be necessary if they'd simply redesign the darn paint can ;)
David
Mr.Bean's
Bill Hammond, Oregon Coast
>Dang, now I'll think of that all day and when I start to laugh people will think I am even goofier than normal...
