200+ woodworking book reviews
Palo Blanco table
Palo Blanco table
Palo Blanco table
Clay Foster
>This recently completed table is made from spalted Palo Blanco. 50" long, 33" wide at the wide end, and 16" high.
Re: Palo Blanco table
>Very nice. The base is particularly so.
Clint
Clay, do you know...
>...which kind of palo blanco that is? One is another name for Venezuelan boxwood and the other is a nickname for primavera, which has a grain a lot like mahogany only it is blond in color.
Nice simple muscular design. Is this on spec or for a specific interior?
white wood
Clay Foster
>Palo Blanco is also what hackberry is called in Mexico. I milled the crotch of a dead hackberry into 4 slabs with a chain saw. This is two of them. I planed them flat with a router on a sled, and then sanded them smooth.
I really enjoy milling salvaged trees into lumber. I've got about 2,000 bd'in various stages of drying. It's all local hardwoods, such as pecan, elm, ash, sycamore, most of it quartersawn, salvaged from construction sites.
A couple of weeks ago I sawed out 2 burled elm planks, 9'long, about 16" wide, and quarter sawn about 3" thick. Also have about another 200 bd' from the same tree random width and length QS.
Forgot your other question
Clay Foster
>This was made for our home. Some of my collection of African household objects are displayed on it.
I should have known
>Common names like Palo Blanco are almost always colloquial, especially in Latin America. It never occurred to me that this might be another Mexican or Texan name for something that is indigenous to the US as well.
Anyhow, thanks for the inspiration about chainsaw milling. Proves you don't need an Alaskan mill to slab out some nice stuff. The irregular chainsaw marks can add an interesting character, too.
What kind of bit are you using in your router when you use it as a surfacing machine?
Does sound a lot better than hackberry...
John in New Mexico
>Colloquial names in Mexico are mind boggling. I was once in a restaraunt in Zacatecas with a couple other geologists and a sample helper. One guy wanted to order a little bowl of fruit instead of the huge bowl they normally brought out. Our sampler was from Sonora and tried every version of bowl he could think of. Finally we got out a dictionary looked up bowl in english and had the waitress pick out the words she knew in spanish from the entry. Our sampler then recognized which one of those was the one for "little bowl", though he hadn't thought of it til then, as it wasn't commonly used in Sonora. I still don't know why using two words in spanish (little bowl) didn't work, and no one could explain it to me then either.
John
Re: I should have known
Clay Foster
>Palo Blanco sounds much more exotic than hackberry. There's also palo pinto, palo duro, palo verde...
I use a 1/2"diameter plunge cut up spiral bit, because it is the most appropriate of the few bits I have. I think most any bit that's flat on the bottom would work.
