Oil & Water?
>If I understand you, you stained the piece, then applied waterbase Poly, and THEN put oil poly over that, correct?
Was the stain oil based? Is the pigment being pulled in the water based poly?
It not clear to me exactly what's happening, but from what I can tell you've got a real mess on your hands that I would tend to strip off completely and start over. If you go that route, do not mix finishes. I have noted a tendency of some waterborne finishes to leach color from dye-stained wood. The usual remedy is to seal the stain under a binding coat such as dewaxed shellac.
If you go with a sealer coat under the poly, make sure that your shellac is fresh or freshly mixed, because I've been told by one major waterborne maker that a binding coat with too much "age" will tend to develope shrink cracks under waterborne finishes, and those cracks then translate into the waterborne finish above.
mm
