>I am joining 2.5" thick mesquite lengthwise. Is glue suffecient or do I need dowels, biscuits, etc. to reinforce the joint. Three pieces will be edge glued to make up a 24" by 75" by 2.5" thick piece.
>You didn't mention what you will do with the plank after you glue it up, but endgrain glue joints are just about worthless if the piece must have any strength or integrity at all. The only place I could imagine not reinforcing the joint would be if it was intended to be edge glued to other pieces on either side. That way, the adjacent pieces would provide the reinforcement.
The problem with any kind of butt joint for this is that, even with reinforcement, the shoulders of the joint will want to separate under any load. The best reinforcement would be the longest loose tenon you can make. Dowels have their own problems with glueline integrity over time, and certainly you would need big dowels or tenons in any case, like 1" thick/diameter.
The accepted method of end joining two pieces is to make a scarf joint, in which both pieces have very long (7:1 or longer) oblique cuts that will go together with effectively as much strength as regular edge-grain glueups. Make sure the pieces mate as accurately as possible and use an appropriate glue.
>I must have been unclear, it is an edge grain glue up. I have two pieces 6"x75" and one piece 12"x75" that I want to edge glue to make 24"wide. Is this ok Ellis? Brian
>All I saw was lengthwise and somehow that said end to end. I must be getting senile. Anyhow, you don't need any reinforcements for those joints. Sorry.
