Poor mans mortises
Stephen Kirk in Quakertown, PA
>I'm building a workbench for a friend and I'm using standard 2x lumber, so I'll be gluing up 2 pieces for the legs. I'm using mortise and tenon joinery to provide good strength. Normally, we'd glue up the legs and then drill/rout/chop the mortise. But, I figured, why not lay out the mortise location on the inside of each leg half and then rout out half the width of the full mortise. I freehand rout close to my lines to the depth I need (which will turn into the width of the mortise when the two halves are put together). Then I come back with a chisel to clean up the edges. I found that the router leaves a nice smooth cut on what will end up being the wall of the mortise, where you want a good surface. All in all, a fast way to cut them I found. Working freehand can really save some time, not having to set up fences and such. If you stay close to the line, there isn't much clean up to do with the chisels.
Some of my mortises are even stepped, and these were easy to cut this way. If anyone else ever does glued up legs with mortises, maybe this is worth considering.
