OT Replacing Flails in a chipper/shredder
Ken Krawford
>I'm going to look at a used Troybuilt chipper/shredder tomorrow. The owner says the flails need to be replaced. Has anyone done this? How big a deal is it?
BTW, this machine is about 6 yrs old, looks to be in good condition, has a 10hp motor and asking price is $275. Does this sound fair?
Thanks for your opinions.
Re: OT Replacing Flails in a chipper/shredder
>I don't have a Troy built, I have a "Yard Machine" by MTD. They may be similar. I just recently replaced my knives and my flails. I've got two knives and four flails.
It's doable, it is just a PITA. I had to take off the hopper intake and then take off the portion that holds the knives and the flails (numerous bolts). I then hit the flail bolts with lots of WD-40. They came off relatively easily after a while. Changing the knives for the chipper part was more involved. You may also want to change or sharpen the blade in the shredder part (it is like a small lawn mower blade).
New, a smaller one ran me about $450 a couple of years ago - but that was a 6.5 hp.
LOL Don't do what I did..
MaxM
>I have the Tomahawk model. The flails are small rectangles with two holes to pivot on and the corners are cut to make a "tooth". I made the mistaske of removing the entire assembly from the machine.....do not do this. On either side is a hole that will line up with the pivot shafts so you can tap the shaft though the opposite side. There are small cotter pins that have to be removed first. Also, I just flipped the flails instead of replacing them.
The chipper knife can be sharpened on a belt sander. ONLY sharpen the angled surface. Leave the flat side alone.
I have changed the knives but never
Mike in Paradise
>the flayers. I have an MTD which makes TroyBuilt so I would assume that they are similar.
To change the knives I undo 3 bolt for the front chute , 3 bolts for the side chute and access from there. I don't take off the hopper.
Takes about 15 minutes. Not sure about the flayers but here is a picture of mine.
