>I know I read about two or three similar 3-5 volt, small cordless screwdrivers here fairly recently like the one shown here, but for the life of me I can't find it. Anyone have one of these and are there any recommendations as to which are better? Worse?
>I have the B&D Model you have displayed in the picture and find it very handy. The other day I installed the apron on a table using the pocket-hole method and used this driver to put in about 25 screws into solid oak. The amount of torque is quite amazing actually. It doesn't drive too fast either which makes it easier to hold things in place. With a regular driver, I find it difficult to control the weight and the speed while doing delicate jobs. The little driver also squeezes into tighter spots and I didn't have to use a a 6" driver bit when assembling using the pocket holes.
I won my driver at a work party and wouldn't likely have bought one otherwise, but I'm glad I have it.
>I bought the Kobalt (Lowes Store brand?) version of this and took it back. I use one in my work as a Home Inspector to spin Panel screws in and out. What I did not like about it was that the collet or chuck is not deep enough to use on of the reversible bits. Phillips on one end and straight on the other. The unit came with two bits, but there is no on board storage for the alternate bit. Since I switch back forth frequently, I would have to care the alternate in my pocket.
I am on "stupid" design kick. Its stupid that they did not make the collet deeper or provide a clip for the spare bit. I took it back.
A friend gave me the Riobi one for Christmas. Significantly more money, but it came with two LIon batteries and a charger. It has a couple of things I don't like. The battery has a "butt" cap that makes it tough to get in and out of my pocket. What I want is a small slender compact unit that does not necessarily include the hinge. I don't "get" anything out of the hinge.
>I have the Bosch model. It is a little powerhouse. Easily drove 4" #10 into Oak and BB Ply. It's not cheap, but if you're doing a lot of screwing, well worth the money.
>I think I remember seeing a blurb about these drivers in a recent issue of either Fine Woodworking or WOOD magazine. I think it was the former, but I'm not entirely sure.
>I have a Craftsman version of this type that cost about $25 and wouldn't be without it. They last several years before the batteries give out and I just chuck it and buy another.
>Good question. Until I bought this DuraPro at Costco for about $15, I'd forgotten just how handy these little guys are. This once comes with a very neat wrap around velcro case with belt loop, 6 screwdriver bits, 6 nut drivers - in the side pouch - and 2 drill bits sized for pilot holes. The trigger is double action, pull in the top and it drives, pull in the bottom and it extracts. Below the trigger is a slide switch that locks the chuck so you can just twist the whole thing, and controls an LED light which I never think to use.
It's 6 volts, but isn't going to be driving #10 screws directly into hardwood. OTOH, I've used it extensively during renos to my boat, and it gets into places where even a hand driver couldn't.
