preparing wood...
preparing wood...
preparing wood...
Webster Stump
>I need some info. Today i went out in the woods and cut some trees down for lumber. A couple of them were already down and so I also cut a few of those up. One of them was a cedar tree, it looks like great wood for turning. I cut the chunks up in about 16-18" logs and i was wondering how to prepare this wood. Sealing the ends, drying it and so on. These trees were free so i couldnt pass them up. The logs i am taking to the saw mill, however the cedar i dont know how to preserve it for either selling or my own use. I would appriciate any response. Thanks
Webster
Re: preparing wood...
>You might want to post this question on the turning forum if you want to preserve turning blanks. You might get more responses.
If you want to preserve a blank for a while, you should coat the ends with some sort of sealer. There are commercial preparations you can buy at Wood Craft and similar places. You can also get Anchorseal on line at UC Coatings. (UCCoatings.com) Also, you can coat the ends with latex Paint (several coats).
Generally, you should split the logs right down the middle to relive the stresses set up by the shrinkage caused by drying. Leave the pieces as long as possible. Most of the damage will be at the ends. If you lose 6" off the end of a 12' log, it not a big deal, but if you lose 6" off the end of a 12 inch blank, its a disaster.
You can bag the blanks in plastic bags and they will be fine for a few days, but they may begin to splat after a while and eventually they may rot. If I have short blanks, I stand them on end and put a plastic bag over them. The lower end is kept wet by the ground and the top by the bag.
Then you can turn the blanks green. Rough out the bowls to about ten percent thickness for diameter. That is, make a ten inch bowl one inch thick, 12" bowl should be about 1 1/4" thick. Put them in a paper bag and let them dry slowly for six months or a year. Or, weigh them and turn them when they stop losing weight. This is called a twice turned bowl, once green and again when dry. You will lose far fewer roughed bowls than if you just try to dry blocks of wood. The �extra� thickness give you enough to true up the bowl after the blank warps.
You can also turn green wood to finish and let the bowl warp. Some people really like the sort of organic form of the warped bowls. Either you do or you don't. Try it, you might like it and the wood was free.
