>How does one calculate linear feet per minute into RPM?
Case in point.
The Performax drumsander conveyor belt is adjustable from 0-10 linear feet per minute. What is the formula for determining RPM? I know the diameter of a 'driven pulley' is going to part of the equation, but I don't know what that will be yet.
Also if someone has one of these machines, what is the HP and motor type (AC or DC variable speed?) of the conveyor motor?
>I have an older 16/32 Performax, probably ten years old and made before they were bought by WMH (?) I think.
The motor on my drum is a 1 HP Marathon brand motor turning 1725 RPMs
The motor driving the feed belt is a Dayton. Permanent Magnet Gear Motor. Model 4Z537A Armature Volts 90DC 98:1 Gear Ratio 1/30 input HP RPM 32 @ Full Load 43 Inch pounds of Torque @ Full Load
To calculate the feed rate, you need to know the circumference of the rollers driving the belt and the RPM's you are turning it. (Circumference is Pi times Diameter) So if your drive a 2" roller (mine are much smaller) each revolution would advance the belt 2 Pi inches or about 6 1/4". So, turning a 2" roller about 2 revolution a minute would produce a feed rate of about one foot a minute. 20 RPM would translate to about ten feet per minute. If you used one inch drive rollers you would have to go between four and forty rpm to go from one FPM to ten FPM.
Clearly the torque is important also. A motor too small would just stop under load.
I also think a larger motor driving the drum would be beneficial some times.
PS. I checked and I have a rubber roller five inches in diameter 12� long mount on a 1� shaft that projects five inches from each end. The rubber appears to be about what tires are made of. Its yours for the shipping.
If you want the roller, E-mail me your snail mail address and I will send it to you. You can send me a check for the shipping. I don't think it will fit in any fo the flat rate boxes, and I probably would send it UPS, but I think it would be about $10 or $12.
The shame is I had two feed rollers out of a Belsaw planer, that would have been great for your project, but I gave them away.
