Second pic post
Second pic post
Second pic post
Mike from Tn.
>Hope to get better. Still a little blury.
Re: Second pic post
Hey Mr. Ellis
Mike from Tn.
>I think my original is out of focus. This is my first digital camra.Haven't figgered out the editing software yet.
Re: Second pic post
Hey Mr. Mike
>If your reduced size image is blurry, odds are that your original is also blurry, regardless of your software or image resizing technique. That is actually a very nice shot of a good looking bowl, but I agree, it's pretty blurry. I'd make sure you're shooting at your camera's highest or second highest quality setting. If you're not using flash, check to see that your shutter speed is at least 1/60 sec. and that you are holding the camera as steady as possible. Anything slower than that requires a tripod.
This is a nice second attempt. Keep up the good work. You'll be wowing us soon.
Ellis Walentine, Host
Re: Second pic post
Re: Hey Mr. Mike
Ken Oakley-Sunny St. Cloud, Fla.
>He did a lot better than I did on my first attempt. And my second attempt for that matter. I just bought a new Canon S2IS, that has more controls,dials, buttons, and DooDads than a 747 jet so I probably won't live long enough to master it. Keeps my mind active though. That could be dangerous.
Re: Second pic post
I recently got the S3IS
Stephen Kirk in Quakertown, PA
>Which is basically the same camera. It shoots great, and I kinda like all those dials and buttons. Auto mode (usually with flash) is pretty decent most of the time. The macro modes work well too. The book makes nice night time reading.
I was thinking of hitting a local community college for an intro photography class, just to learn the ins and outs and hopefully take some decent pictures. Maybe I can even learn what F-Stops are!!!
Re: Second pic post
Re: Second pic post
Keith Newton
>Mike, In looking at your photo, I was trying to diagnose your problem, and make a couple of suggestions to help you improve.
First it is obvious that you used a flash, so the blur is not from motion, and the chairs in the back / distance, are sharper than the subject in the middle, so I think you did one of two things.
You either pressed the shutter button too fast, without giving the camera to focus on the subject, or you were too close for the lens to focus for the standard setting. Next time try this. Press the shutter button half way, and wait for it to focus. If it is still blurry, back up a bit, or look for a setting with a little flower icon. If it is a button, pressing it once will turn it on, pressing it again will turn it off, or it may be on a dial etc. but this will usually let you get in a lot closer.
If you are in the close, probably macro in your manual, it is best not to use the flash, because it just burns up the subject. Find a spot with good diffused light, like near a window, but not in direct sun. Even outside, if you are near the edge of shade and full sun, will give good results.
I know that if you are new to photography, understanding the manual is like learning a new language. The best way to learn is taking one step at a time, so go get that camera out, and see if you can find that macro setting, and play with it, and leave that flash off.
Another thing that will make your turnings look better, is to have a plain background. You can pick up a white poster-board from hobby-lobby, or art supply stores for a few bucks. Get two. Set the turning on one with it leaning against something behind the far end, causing it to form a nice smooth arc up behind the turning from the way you plan to shoot it.
Then spring clamp the other to a tripod, or anything that will hold it vertical to one side, then bound light off of it.
From the other side, you can play around with another clamp type work light, without diffusing it, you can pick up nice detail, by moving it in and out, and more from the side to top, until you find the best balance. Play with things and have fun, and you will get better.
Re: Second pic post
Re: I recently got the S3IS
Keith Newton
>Ken and Stephen, My last camera was the S2, and I moved to the S3- IS about six months ago. Wow, these are great cameras for such a small package, and bang for the buck.
They have packed a lot into these cameras, and I have been having a lot of fun using them. I almost never use the flash. That is the beautiful thing about the image stabilizer, it allows you to hand-hold the camera under situations that before would require you to use a tripod, or flash. It is also very good at reading the type of light, and compensating for imbalances or color shifts due to that.
Stephen, f-stop refers to the size of aperture. The higher number, the smaller the opening in the aperture, and the greater the depth of field. This means that the shutter speed will need to be slower to get the right exposure, unless you shoot at a higher ISO setting, which of course means lower resolution quality. I normally leave mine set on P for program, instead of auto.
One thing that I do a lot which helps me get better shots, is to use the bracket mode, and have it set for a-usually 2/3 stops. Then each time I press the shutter button, it takes three shots. the first will be what the camera thinks is right, the next will be under, and the next will be over that. If you can take the time to review these three shots, it will help you decide how to take your next shots.
At about the time I ordered my S3, I had started playing with the continuous shoot mode, where you just hold the button down, and it shoots 1.5 shots per second. You can get some great candid shots that just can't be had by posing people in front of a camera. I do this especially when friends, and family are just getting together, and or leaving, I may shoot 100 shots, and throw away 99 of them, but that one is the one that I want, and would have missed without trying this trick. I got a 4 gig card this time. Sometimes I may get ten in a row that I keep. But this way, I feel like I capture the spirit of the person, rather than the shell.
Re: Second pic post
>I also have the S1IS but it is at Canon repair for the second time in a year and been there two months waiting for a part. When it does work it is a fantastic little camera. I need a good camera as I sell a lot on Ebay and a good picture goes a long way helping to sell an item. Also great when the Biker Babes come to Daytona for Bike week and during Spring Break. Just be ready when somebody yells "Show Me Your T--s".
