OT: Screw Drive Garage Door Opener
Robert Hutchins
>My neighbor - a pediatics resident - got his car locked in the garage when the opener failed. I got the door open and his car out, now I'm trying to repair the door. It has a threaded rod and traveler attached to the door . Something caused the part of the traveler that rides on the threaded rod to hyperextend beyond the electric switch that is supposed to limit its travel. Can anyone suggest what might have caused this?
The door was damaged slightly but can be repaired with some U-channel, pop rivets and little of Mother Necessity's Ingenuity. Before putting things back together, I need to find out what triggered the problem and fix the cause; however I know nothing about this type of opener. (Prolly wouldn't hurt to have a diagram to be sure I put it back together correctly, too.) The motor operates and the screw turns.
Can you recommend an online tutorial and trouble shooting guide? The traveler has obviously been banging into the drywall at the end of the shaft for some time. The limiter switch has a flimsy little plastic arm that breaks the circuit. Perhaps it has been riding off the traveler. I don't know.
I figured that with all the knowledge and experience in this community, somebody is bound to have been down this path before and can keep me from falling in the ditch.
Re: OT: Screw Drive Garage Door Opener
Keith Newton
>On most of them, you can easily see the limit switches, even the contacts, but it sounds like this one may be off on the end of the track run? No. Well it is probably a normally closed, when it is running that way. It may have gotten stuck. If you have a tester, you might check to see if it is opening, and make sure that whatever is supposed to actuate it is aligned properly.
M. McNamee
>Happened to me. Wire from the limit switch that connects to the drive head came off. If all the wires are connected, then there are two items that might have failed. The limit switch or something internal to the drive head. My limit switch is nothing more than a magnetic pickup.
