Migrating Moouse Update
Lee Schierer - McKean, PA
>As I mentioned im a previouis post, my corded optical mouse would start wandering toward the upper left corner of my screen when no one was touching it. There were several suggestions of what to do. I did two things at the same time (yeah, I know only change one variable at a time). Fist I examined the LED in the bottom of the mouse with a magnifying glass and found an extreely fine clear fiber was in the recess. I removed the fiber and also replace the mouse pad. Since I did that my mouse has stayed put. I 'm not really certain whether it was the fiber I removed or the mouse pad, but migration has ended....at least for now.
Lee
Re: Migrating Moouse Update
Jim Toews
>Lee,
I think I see your problem: "...fist I examined...". When working on computer equipment you need to use a hammer, not your fist!
Sorry about that; I couldn't resist.
Cheers!
Jim
John in Ks
>Lee,
You can put the old mouse pad under the cleaned mouse and see if the trouble is still clear. Then you would know if it was the worn mouse pad or the speck of dirt.
Your mouse is shedding....better brush it!
Phil Joines Krum, Tx
Thought of that but,
Lee Schierer, McKean, PA
>I thought about putting the old mouse pad back, but it had already gone to the local landfill.
Lee
