Drywall crack repair- Advice needed
Shakey
>Hi Fellas- I've been in my new home for three years now. I have some drywall cracks from settling of the house, mainly on the door jambs...45 degree angle crack from the top right or left hand corner of the jambs. Since I've never repaired drywall (old home had plaster walls), should I open these cracks up a bit with a knife and use the fiberglass tape to insure they won't recrack, or can I just put joint compound over them and sand it smooth, prime & paint them? Thanks for any help!!
Re: Drywall crack repair- Advice needed
Bill Howatt
>Cracks like this can be a problem and unfortunately are not always totally due to settling. If you are in an area that gets lots of snow, the snow loading on the roof can cause movement as well.
IMO, patching without taping is a waste of time. The one of the functions of the tape is to spread the stresses.
Bill
>If the cracks are less than 1/8" wide, latex acrylic painters' caulk (DAP) will probably do just fine. Squirt it in, level it off, and paint. It's stretchy enough to accommodate any likely future movement.
Settling is not the only cause of movement. Seasonal and/or heating and AC humidity changes are sometimes the culprit.
Clint
James Dillon in MD
>Shakey,
These type of cracks are quite common especially in new homes. Try using a beer can opener (the pointed triangular end) to widen the gap just a little, apply tape, and then your drywall compound. You might have to use several coats of drywall compound to taper the repair a bit. I like the suggested idea of using latex caulk, but have no experience with that approach. Don't be surprised (or discouraged) is the crack reappears. It happens.
Jim
Phil Thien
>+1 on this. Actually, I often use DAP to fill cracks > 1/8". With excellent results.
NickB
>I've used caulk myself, and it's worked well in terms of repairing the crack. However, I've noticed that latex caulk is pretty shiny when painted. Big Stretch (which I use to caulk all my trim) claims to be less shiny (although I've not been in a position to reallly notice as of yet).
Hope this helps,
Nick
Tony - Memphis
>I gotta chime in here. I've repaired many many drywall cracks. I never use tape unless it is a major crack. There are even some new products that are vinyl based that will flex a little. I've had the best luck with pre-mixed joint compound. Our current house had a bunch of cracks. Our issue was shrinkage. No settling. Guess you could say the wood and the compound was settling. Very common for drywallers to slap on a real thick coat of compound and it shrinks as it dries and it cracks. If I had cracks in the drywall, I'd be interested in why. Our old house had similar cracks and we had some issues. Nothing major, but it was more than just settling. Ours were seasonal too. Anyway, good luck with it.
Tony
