>How would one check the draw of a flue?? Is there such a thing as a draft meter?? Flue seemed to be drawing ok,then used some product to clean the deposit out-now no draft. Wonder what happend? When starting a fire,smoke permeates inside the house. Need advice. thanks pw
>I take it that you are burning wood? Is the chimney metal or masonary? You might have partially plugged your flue pipe with the use of the cresote remover product. Tear the flue apart and clean it. The worst thing you can do with a wood burner is to ide or smolder a fire. Builds up cresote fast. You're better off running a small fire hot, than a big one barely burning.
>Paul, I'm sure you are aware this is potentially a very dangerous situation. Don't use the flue (that is, don't have a fire or use your furnace or whatever) until you get the flue cleared, repaired if necessary, and thoroughly inspected.
You can use a match or candle producing a stream of smoke to see if there is a draft, but that would require you have a fire going in the fireplace and that is a likely source of carbon monoxide.
Chimney sweeps can clean the flue and many have a camera they can inspect it with internally. Not terribly expensive and cheaper than a dirt nap.
