Lazy Susan Display into 2 shelves???
Ray Carson in Lawrenceville, NJ
>Hello,
I'm modifying a lazy susan carousel that LOML displays some horse figurines on. After removing the lazy susan mechanism and VERY carefully cutting the disc in half I discovered that the display stand is veneered MDF.
The plan was to attach a back and a bracket as shown in my sketch. The material thickness of the existing carousel is a little under 1/2" thick for each layer I'm showing. So I have 1 1/2" overall. But, as you can see, only the larger disc has enough "meat" to sustain any type of fastener, biscuit, etc.
I was going to make the new parts out of cherry because once stained, it will match the existing veneer. I don't want any visible fasteners so my thought was biscuits. I'm leary of using screws in the MDF, but will not discount them.
The carousel was about 18" across giving me a shelf that sticks out from the wall about 9 inches or so. I'm concerned with putting biscuits into 1/2" MDF with a VERY thin veneer (bulging) due to the swelling of the biscuits, and also the weight of the figurines.
I just noticed that in my sketch I am showing the cut going through four of the recesses. Actually the cut was made so that each shelf holds 6 figurines.
Any suggestions would be appreciated.
Thanks,
Ray
Re: Lazy Susan Display into 2 shelves???
John in Kerrville
>If you used the biscuits and used epoxy instead of a water based glue, that might eliminatethe swelling issue. However, epoxy is thin and might soak into the MDF to the point of leaving a "dry" joint. You might coat the edges of the mdf several times to see if it "disappears". Try a test joint.
john
Ed Mulligan, Cape Cod
>Ray -
1/2" mdf is routinely joined with biscuits. There may be a slight swelling if waterbase glue is used but this will shrink over time.
The problem I think you may be worried about is when biscuits are used to join solid wood; the wood swells, wood is sanded, wood shrinks leaving a biscuit shaped depression in the surface.
You won't be doing any sanding on that thin veneer so I think you are ok to proceed with biscuits and waterbase glue.
The suggestion to use epoxy is good as well. I've successfully used West System with no problems, no starved or dry joints.
Ed
Re: Lazy susan - Thanks John, thanks Ed.
>John and Ed,
I guess maybe I'm over analyzing it too much. The epoxy is a good idea. I would imagine that using a polyurethane glue would also be bad because it would expand and swell the joint. ??
If I felt the need for a couple of screws, I'm guessing that a coarse thread would be better than a fine threaded fastener. ??
Ray
poly and screws
>"polyurethane glue would also be bad because it would expand and swell the joint. ??"
Ray - Poly glue foams in loose joints but I've never heard of it swelling a joint. Maybe another poster can provide more info?
"If I felt the need for a couple of screws, I'm guessing that a coarse thread would be better than a fine threaded fastener. ?? "
Screws into end grain mdf are likely to split the mdf. I'd stay away from them for your shelf. If you do decide to use them, run some tests on scrap to see how the mdf behaves.
Good luck,
Ed
I don't see any problem with biscuits...
>... and I definitely wouldn't be screwing into the edge of MDF. I also wouldn't worry about the glue. Epoxy might be better than yellow or hide glue because it doesn't have any water in it, but I doubt that expansion will be an issue. I agree that polyurethane glue might be a gamble because of the expansion of the glue as it cures. I must say I've never tried it though. You might want to run a sample first, if you plan to use polyurethane glue.
Looks like a fun project. Send pix when you finish it.
