OT - Dbl Hung Window Rope - need help!
Joe in a Cleveland suburb
>Hi.
I've replaced a number of broken ropes in my double hung windows. You know, the rope breaks, the weight falls, and the windows slams shut.
So far, each time I've gone to replace the ropes (I always do both sides regardless of which one is broken) I've always struggled with getting the rope the correct length - not too long, not too short. What is the trick!
The second problem is the knot on the weight. I know there is a specific knot to use. One that tightens on itself. I remember seeing an article someplace on this subject and for the life of me can't remember where.
Anybody know of a site with procedures on this? I am asking because my in laws have asked me to help them tonight with some broken ropes... uhg... sigh.... :)
Thank you!
Joe
Re: OT - Dbl Hung Window Rope - need help!
Steve in CT
>I replaced the ropes on the lower sash of all 28 windows in my house. Replaced a lot of glaze,too. I used a simple overhand knot and have had zero failures with cheap cotton rope. I put the knot in the window, rest the window on the sill and hold the rope up to the pulley to gauge how long to cut the rope. Use 2 half hitches on the weight. It's always fun doing house repairs for the in-laws. Good luck.
Re: OT - Dbl Hung Window Rope - need help! *LINK*
Mike Fitterling
>For the knot on the weight try a figure-of-eight. It will give you three times the diameter of the rope, making sure the knot will not slip through the hole in the weight.
http://en.wikipedia.org/wiki/Figure-of-eight_knot
Art
>Joe, it',s goin to be pretty cold tonight and changing window is a warm weather job. A good rule of thumb for rope lengths is distance of sash plus 1/4. If the sash measures 28 inches the rope should be 35 inches. That distance is between the knot pocket and the weight. You have to cut extra for the knots. If the old rope is all there just use that lenght. Look at the knots that were used, or follow the previous advice.
I Replaced Rope With Chain
>Good Morning Joe,
I hated that job, especially fishing out the fallen weight, and often having to distruct part of the window frame to get inside the weight channel. Lousey rope! I used chain sold for window weight purposes. Secured with wire. Never a repeat problem.
George
>This is one of those things where the first one takes four hours. The second one takes two hours and after that thirty minutes or an hour each.
Watch what you do and learn from your missteps. Once you get one right, measure the length of the rope. Remember the knot. Then repeat the success.
There is rope know as sash cord. Use the good stuff.
Here's the knot! *LINK*
Lee Schierer, McKean, PA
>The knot I like to use when I do this is a fishermans knot. It stays tight and holds the weight in the center of the weight channel because the rope ends up directly above the holw in the weight, not off tot he side so the weight is canted as it hangs.
Sash cord it the proper rope to use, though you could probably get away with nylon rope. Make sure you lubricate the pullies at the top.
Lee
Fishermans knot
Use Chain
Gene Gauss
>I replaced all of the sash weight ropes in my parents' house with chains when I was about 13. My brother and I sold the house after my mother died in 2000, and not another one had to be replaced after 52 years of use. I recall I purchased the chain from a hardware store that stocked it expressly for that purpose. I think they also had a spiral ring things that were used to hold the chain in the circular recesses in the sides of the sash. The old story: Do it once and do it right. Gene Gauss
Thanks all.
Scaffold hitch
Tom Dunlap
>The scaffold hitch goes by some other names too. Double Fisherman's on a bite/bight.
I use the SH to terminate ALL of my rope to biner connections on my climbing ropes. If it's the one that many arborists use for their life support you can bet that it's secure enough for sash weights.
The advantage of a SH is that the tail of the hitch comes back out of the double overhand knots parallel to the rope making it 'fair' which will eliminate any snags.
The SH will snug down onto any eye, carabiner or sash weight securely.
Sash rope *LINK*
Tom Dunlap
>Here's something that I found when I googled 'sash rope'
Sash rope
