lunch box planer problem
joey
>My Rigid planer is having a hard time advancing lumber. The rollers are clean, but the wood stops and I need to push it through. Anyone with a similar problem? Thanks, Joe
Re: lunch box planer problem
I have the same problem with my Delta
Stephen Kirk in Quakertown PA
>When I notice that happening, I clean the rollers and wax the beds. Also make sure your blades are sharp. The usually gets it running nice and smooth again. If the rollers on the Rigid are anything like the Delta, make sure the entire roller is clean. I have to keep cycling the motor on the Delta to spin the rollers, clean them, cycle again, etc.
Dale Stansbery
>I haven't tried this yet (shop closed for winter), but Bleche White tire cleaner does a great job of removing the oxidized slick rubber on my golf grips, and I'm thinking it will work as well on my planer rollers. Once they get old, other less aggressive cleaning hasn't worked too well for me.
They say that you are not supposed to but
Mike in Paradise
>I give my Dewalts rollers a wipe with lacquer thinner when it stops feeding and this seems to make the rollers stick again.
I have been doing it for 6 years now and so far so good.
Another thought - slight hijack
>As I don't own a jointer, I often send boards without one good side through the planer. I have noticed that the boards may stick a bit until I get them closer to being flat. I wonder if the board not sitting flat on the table and the rollers not catching the top surface correctly could cause some problems.
Might be worth checking out if you continue to have any issues. Dont' know if anyone else has thoughts on this.
Or alcohol?
>That would be the rubbing alcohol, although the use of drinking alcohol might even be better since it's will leave a sticky reside ;)
Happy Woodworking!
Bob Fawcett
>I had a similar problem the other day with my Delta. I raised the cutter head way up and found a groove cut in the floor with raised edges. Seems someone must have put a board through with a nail or staple in it, but with the metal side against the table. A little fine sandpaper wrapped around a wood block took care of it.
