>I have tried the wood bleach to remove spots but they do not come off all the way. It seems like they are from pet urine not just water. They seem less visible when dry but when you wet it to rinse, it shows up dark again. Will they show up dark when you stain?
>If I'm not mistaken, pet stains can darken oak --or other wood rich in tannic acid -- irrevocably. It's the equivalent of fuming with ammonia, a technique that was very common a hundred years ago. I know of no chemical way to put this genie back in the bottle. Maybe one of the gurus will chime in, but I don't know the answer.
It is possible that you could do some spot bleaching with a stronger wood bleach, such as Kleen Strip two-part wood bleach. But, I don't know how you would control the process, or limit it to just the spots that need to be lightened. Maybe a little practice and a small artist's brush would help.
Another possibility would be to pre-stain the lighter wood to match the stained parts, and then put a final coat of a darker stain on the whole shooting match.
Sorry for such speculative answers. Let us know what you finally do.
>Any water source will stain/darken oak. If you stain over it, it will just get darker. You need to sand the area as much as possible, or replace the boards.
>There's always the option of cutting out the offending spot and putting in a decorative inlay of some sort. Then it won't be stained -- it will be customized.
>When you say "wood bleach" are you referring to oxalic acid? That's the bleach used to remove chemical stains from wood. I don't know if it works on pet urine though.
>I'd be tempted to give the oak a wash-coat of 1 pound cut of shellac as a sealer and then stain over the shellac for hopefully a non blotchy appearance. Dale
