When do you sand?
When do you sand?
When do you sand?
>When you make a piece of furniture, when do you sand?
Do you sand each piece of wood and then cut out the actual piece for the project? Or do you Plane and square the stock and cut the pieces and then dry assemble the project and after you have it ready for final assembly, Sand? Or do you wait until after final assembly?
Re: When do you sand?
All of the above.
Neal in San Jose
>It just depends on the piece. Many things would be difficult or impossible to sand after assembly, but some, like doors, I run thru the wide drum sander after assembly to true up all the joints and finish sand after that.
YUP !
s.mackay@worldnet.att.net
Doug in Denver
>Mostly after assembly because I raise a lot of grain wiping off glue with water!
>Constantly. For chairs I usually grind the seats and sand to 150-220 grit before glue-up. The spindles, crests, loops, backs and turnings are all sanded pre-assembly. After glue-up, I sand again. I then raise the grain and sand again. Then I stain (or paint) and sand lightly. I also sand lightly between coats of finish.
Tables and stuff are sanded before assembly and after assembly.
That's why I buy the 50 packs for my ROS :). I also get the flat sheets in 50 packs.
That's a very big subject, Barry
>If I had to state a couple rules of thumb, I'd say that you sand sub-components prior to final assembly, but not prior to sub-assembly. For example, if you are making a table with a veneer top and solid edging, apply the edging first, then level it and sand it. You don't pre-sand anything prior to joinery (at least I don't), and if you can possibly use a hand plane to give you a perfect surface, you forget about sanding entirely.
I'd love to delve deeper into this, but those are the first things off the top of my head.
Ellis Walentine, Host
Robert R Clough - Thorncraft
>I have to agree with Neal - early and often. I do some sanding prior to sub assembly for general smoothness, do my fitting, changing, filling bad areas, etc., and then do a final sanding prior to dyeing/staining if any, and glueing. Don't be afraid to sand. It is a real and definite part of fitting.
Re: When do you sand? Now, you will
Carol from AZ
>discover why I am designing a drum sander. My practice has been to sand the planer marks off lumber after is it rough cut to length. If I am edge joining, I do that first, then sand the planer marks. 120 grit.
Build from there. If there will be difficult areas after assembly, I'll sand to finish grit before glue up. The minor amount of re-sand due to glue up is no problem. After final assembly and re-sanding, then its once over at the final grit.
I don't really know if that saves a lot of time. It does save me a lot of frustration and that's good enough for me.
Re: That's a very big subject, Barry
>Ellis, you said:
"and if you can possibly use a hand plane to give you a perfect surface, you forget about sanding entirely."
This is a CONCEPT for me. I am self taught as a woodworker and it never occurred to me that you could hand plane to this level. Maybe I need to check out the hand tool forum.
Re: handplanes
Glenn Madsen near San Francisco
>The use of a handplane to that level of finish is a goal not immediately reached. And with some woods, and many projects, seldom if ever.
But that doesn't stop some of us from trying. I dislike sanding that much.
Planed surfaces...
>... are not difficult to get perfect with most woods. Of course the gnarlier or more figured the wood is, the more sophisticated you need to be in your choice and tuning of your plane. Some woods simply don't plane well ever, in my experience, and those usually get scraped and/or sanded instead. Looking closely at a planed surface vs a sanded one, you can really see the difference. The wood cells are sliced, not abraded, and you can see the character of the wood more clearly. Of course, if you sand to a reasonably fine grit and then put a film finish on, you get a similar appearance.
By all means let the hand tool gurus get you started down the slippery slope. Hand tools and machines are not mutually exclusive in an efficient shop. And the rewards of hand tools are worth the effort of acquiring and learning to use them.
