sanding sealer
sanding sealer
sanding sealer
George Brown
>what is in sanding sealer. saw some in a shop which had seporated into a spirit type liquid and a soap like goo. at �14.00 a pint it seemed expensive. are there alternatives for a penny pinching beginner?
PS my Chemist only sells things that come in cartons or bottles so asking for some curious compound would probably rquire a note from my doctor....
thanks
Re: sanding sealer
what is sanding sealer...
bill tindal, E.TN
>Sanding sealer is simply a formulation that sands easily. It can be a formulation that contains a low molecular weight film forming polymer which because it is low molecular weight will be brittle, or it may be an inherently brittle film forming resin and/or it may have a "soap" (for example zinc stearate) added to make it sand with out gumming up sand paper. If you aren't having any problem sanding your first coat of finish, there is no need to use a sanding sealer.
I don't think it is practical to formulate home made finishes. While one might be able to get the raw ingredients, but the chemical transformations to make a finish would be difficult to safely achieve on the stove.
Re: sanding sealer
Re: sanding sealer
Terence Rice
>I use a 50/50 mix of gloss lacquer and lacquer thinner. It penetrates the wood and seals off smaller pores.
Re: sanding sealer
Re: sanding sealer
Glenn Madsen near San Francisco
>If you need it, and certainly not every project does, you can often use dewaxed shellac, cut to about a 1 lb weight, in the role of sanding sealer.
Cheap. Quick. Compatible with most every finish. Easy to apply. Sands nicely. Available easily.
But it's not always needed, certainly. I guess I use it on maybe 40% of my projects, and most of those end up being mostly shellac finished anyhow.
