some more thoughts
bill tindal, E.TN
>You may know about what you are doing way more than I, and if so, ignore the rest.
It will be easy sawing a small fraction of true quartered beech (not rift) from a log if it is big enough and clear enough, both problems with beech that grows in North America. Big and clear is not such a problem with European beech, which is why I believe planes (English tradition) were made of beech rather than something else. In my experience you will get one quartered 4' plank from the center of each log. The rest will be rift or some combination of rift and flat.
However, beech is cheap. In fact there is usually no market for it and it gets left in the woods. So you can buy trees for firewood prices. Before I decided that beech was no better than most any other wood for planes, and that rift cuts were just as good as quartered, I laid in a stock of 4" quartered beech very easily. I cut some fair sized beech trees. Blocked the lower trunk into 24" sections and then with the chain saw sawed a 4" plank out of the heart of each section, yielding a 4" perfectly quartered plank. The rest went to firewood, which I needed. In a couple of hours I had more beech than I would ever practically use to make planes for just myself. The 4" planks were easy to dry, if in general you know how to dry lumber,with no end splitting. The tree center (pith) shattered, as it always will, but I was left with lumber on each side that was big enough for plane bodies.
I have heard that N. American plane makers boiled their beech. I have no idea if this is true, but it makes sense. Boiling will be like steaming and it will tame beech's propensity to dry with tension.
