Broken pot metal knob-- any hope of repair?
Dave Morris
>One of the pot-metal adjustment knobs that hold the table on this old Jet bandsaw is broken. It has four little "balls", about 1/2" in diameter, at the end of a small "neck" about 1/4" inch in diameter, arranged around the body of the knob so your fingers can grip the knob to tighten it. One of the balls is snapped off at the neck where it joins the body of the knob. I have the broken-off ball/neck, and it's a clean break. Yeah, the knob still functions, but strictly for appearances, I'd like to repair the knob. Unfortunately, this cool-looking old style knob isn't available any longer from Jet as a replacement part.
So what is the best stuff to glue these two pieces back together? JB Weld? Epoxy? Some other kind of space-age two-part ethyl-methyl wonder-bond that I'm not aware of?
Searching the net turned up several threads on different forums about repairing pot metal, but not one of them ever said what finally worked. I did see one product from Caswell Plating that claims to be the bee's knees for pot metal:
http://www.caswellplating.com/aids/solderit.htm (hope I'm not breaking any rules posting this link) Anybody ever used this stuff?
Open to suggestions. I can still fogettaboudit and just use the knob as is, but it'd be nice to fix the knob if possible. I just don't want to use the wrong stuff first and screw up the chance to use whatever product would *really* work in this situation.
Dave-- trying to find the line between "functional" and "just for pretty" in this tool restoration
Re: Broken pot metal knob-- any hope of repair?
Tom Minehan
>I have a "pot metal" eagle decoration hanging on our fireplace that was repaired with JB Weld. One of the wings fractured and the eagle fell on the floor. The repair has worked so far. The joint is stressed by the weight of the eagle.
Steven Antonucci
I used CA glue
steve antonucci
>I had a broken lower guide on my bandsaw, and while I waited for the replacement part, I simply CA glued it back together. I was surprised at how well it's performed, and I haven't even taken the 15 minutes to replace it with the new part on my bench.
Steve
Robin Corell in Atascadero, CA
>It's most likely aluminium and weldable.
If you opt for an epoxy repair you may wish to drill for a small roll pin after the epoxy has cured for a while.
most of the old jet tools were exact copies of other well known tools. some even used a mix of SAE and metric harware. If your broken part is SAE it may be worth looking for a replacement from the type of machine Jet copied.
Robin Corell
>Dave When I need to repair something that is easily brocken I drill out a hole in both pieces and insert a pin. So that alignment isn't a problem I drill the hole larger than my pin. I cut some notches into the pin to give the glue some surface to grab onto. I usually use a pair of diagonal cutters to do this but have also nicked it with a hacksaw. Then I just put on a lot of epoxy and insert the pin and hold it together until dry. If the part fits together really well I use a little acetone to wipe away the epoxy that overflows. You get a very clean and strong joint this way.
Re: Broken pot metal knob-- any hope of repair? *LINK*
John McGaw
>Do you know the specifications for the knob? SAE or metric, threading, etc? If so, you might want to check out Reid Tool's catalog. They carry an amazing assortment of such items along with the hardware to make almost any sort of jig you'd ever need.
Reid Tool Metal Knob Pages
Measure the shaft, buy aftermarket knob
MaxM
>Grizzly sells some or do a search. I bout 2 for my old Rockwell for $7 ea.
Pete LaBelle
>Check on line for Reid Tool Supply. They have all sorts of knobs.
Loyd Lucas
>IF it's truly pot metal, you should be able to silver solder it.
Dave Morris
>Thanks, Robin. Yeah, Jet obviously cloned Delta's 14" bandsaw, and the knob looks to be a dead ringer for the "star wheel" knobs I see on older Delta bandsaws. Problem is, I'd already checked the Servicenet Parts and Repairs portion of the Dewalt/P-C/Delta/B&D website, and this wheel, while shown in the exploded views of older delta BS's, isn't shown on the parts list. According to the web site, this means they are no longer available as replacement parts. :-(
I thought about drilling a hole and pinning it as you suggested (sort of a floating tennon joint, eh? hehehe), and asked around if the part would hold up or shatter in the process, and received conflicting answers. Hence my hesitation, and posting the question on this board.
Dave--- who prefers to gather as much info as possible before acting on a one-shot repair
Dave Morris
>Thanks, John. Done and done. Nope, they don't show anything even remotely resembling this "star wheel" knob. Great web site, though.
Dave--- adding another supplier to his favorites list
Re: Measure the shaft, buy aftermarket knob
Dave Morris
>Yabbut, if all I wanted was a generic aftermarket adjustment knob, I can pick one up at the local Ace hardware store. ;-)
Grizz doesn't have anything that looks like it either.
Dave--- who, if buying a new replacement part, would "like" to find a match for this knob's other siblings on the saw
Is this what your looking for?
MaxM
Looks like it, but...
Dave Morris
>I dunno if it has the same thread pattern. I am going to take the knob to the local hardware store today and see exactly which type of bolt is a thread match.
It looks like you have the same exploded view that I was looking at. That star knob (item number 88) doesn't show up on the parts list at Servicenet for Delta (meaning it's no longer available?) and Jet said they don't carry it anymore. I didn't see that style of knob Grizzly either.
(hopeful voice *on*) "You gunna make my day and tell me an easy match/replacement is only an internet click away? TERRIFIC!" (hopeful voice *off*)
Dave--- off work today, and heading out the door for a dentist appointment
Re: Looks like it, but...
MaxM
>#19 is available, Tension bolt. The knob will remove from the adjuster.
Carol from AZ
>Reid Tool, a click away.
