Delta Band Saw motor
Wayne Carson
>can I put a larger otor on the band saw say 1 1/2hp
Wayne Carson
Re: Delta Band Saw motor
Chris Rosenberger
>Yes you can put a larger motor on your band saw. I have a 2 hp motor on mine.
Re: Delta Band Saw motor *LINK*
James Dillon in MD
>Wayne,
While I have never done it, replacing your current motor with a larger one is very doable. If you don't have it, get Iturra Designs catalog where I think Louis Iturra (the owner of the company) discusses doing this. Unfortunately, he doesn't have a web site. His telephone number is 888-722-7078. If you are having trouble resawing with your present setup, using a good resaw blade can also help. Many people on this forum like the Woodslicer, or Timberwolf. The much more expensive Lenox Pro III carbide-tipped resaw blade is also very good, especially for very hard woods. A review of that blade is given below. Iturra Designs sells the Lenox blade and discusses its use in their catalog. Good luck.
Falberg saw Co
>Yes. You can also put a V-8 on a Moped; but why?
Before you rush out!
Lee Schierer, McKean, PA
>Check to see that the current motor has the belt properly tightened. Delta uses aI thought my motor on my 14" was going bad. What I found after a few minutes of checking was that the belt wasn't tight. I adjusted the tension and the saw was like a brand new saw with a much larger motor. Now it will easily resaw 5-1/2" of maple with out bogging down.
You can send me half the money you would have spent on a new motor if this works... :)
Lee
Re: Before you rush out!
wayne
>what blade do you use for resawing
Resaw blade
>I use a 1/2" 3 (might be 4) tpi Tuff Tooth blade.
Lee
