Re: How about curved section MDF and veneer?
Mark McC
>To get 4 ....3.5" wide x 5/8" thick laminated curved sections out of solid wood, I need to build the jig(likely only one), re saw all the wood into 1/8" thick strips x 4, glue them up one section at a time, clamp to the jig, let it dry, repeat for three more.
Using MDF, I was thinking about gluing up one long 4-5" thick x 3.5" high section made of several MDF strips.
Then bandsaw 4 curved sections out of that long thick strip, and then laminate one strip of solid wood veneer onto each curved section.
Feels easier , except for sanding and making sure each cut section is the same radius, but maybe its not the best way.
M
