Sandpaper Storage
RobV
>I need a better system for storing sandpaper sheets... putting them in a drawer has become a hassle to get to the bottom sheets... I'm thinking of some kind of filing system... show me what you're doing.
Sandpaper Storage
RobV
Re: Sandpaper Storage
Gary Tenney
>A three ring binder with slip covers.
Gary
Pat Evans
>I made one section of shelving in my workshop hutch with horizontal dividers. Sandpaper lays flat, stores by grit, and is easy to get to.
>No pics, but here's what I have done. For 5" ROS, I took an old 5 1/4" floppy disk storage unit and used that. For flat sheets, I have an old plastic filing box that took hanging folders. The sandpaper is in the hanging folders. Both have the advantage of being somewhat portable. I can take them over to the bench and use them there. Otherwise they live on a shelving unit.
>I have a portable version of the one Pat made above. Not sure I like it. For one thing, if you make it be sure to make it big enough to accommodate 9 X 12, not all sand paper is 8 1/2 X 11. Also, I find the sand paper tends to curl and that makes it hard to pull and replace a single sheet. Might work better if you made the slots a little taller and cut a "paper Weight" sheet of quarter inch ply to rest in each bin. Also, make more bins than you think you need. Seems there is always "another" grit. Seems it did not think of 1200, 1500, and 2000. Who knew?
For the ROS I saw in a magazine a little cabinet that had pull out shelves. Each shelf had pins on it made of dowels that fit through the holes in the paper. (You may not need all five or all eight, but maybe three.) This assumes you are using H&L. You put each grit on one face down in a stack. At this point, I thought this was way over the top and really anal. Turns out that you can insert the sander over the pins and it automatically perfectly aligns the paper on the pad. I have not done it, but it has an appeal. OTOH, I might make one piece with the pins and use it as an "aligner".
Here is mine
Mike in Paradise
>I would make it twice as big. Keep the space between the shelfs narrow so the paper cannot curl as much.
Bri in Mtl
>On the right side of the photo above the Kreg jig and below the aircleaner. The shelves slide out and there's also space for the ROS.
Andy Wright
>I use a vinyl expanding file like what you would use to file receipts. It is compact, inexpensive, and it works great for storing partial sheets as well as whole sheets
Charles Sharp
>Look in the current issue of Fine Woodworking.
>Good Morning Rob,
I use a steel upright storage cabinet with shelves for the bulk and boxed stuff. I buy primarily from Klingspor and cut sheets from wide rolls. They are arrangred horizontally by grit, and each grit is separated by 1/4" plywood. I weight the top to keep flatness. The cabinet also houses belts and boxes of 5" discs. I go thru a lot of sandpaper. I have also built tool boxes obligated to each of my sanders. The tool boxes also have room for several boxes of 5" discs, and a selection of belts for each belt sander. To work outdoors, all I have to do is grab the sander box(es) I need and go. The paper is contained within.
George
Re: Sandpaper Storage (pics)
GolfSteve in Calgary
>I found this sandpaper storage unit sitting in the garbage pile in an alley a few years ago. Works great.
Al Killian
>This what I have done. Then I used a wood burner to mark the grits onto the shelf. For the ROS I use a 5.5" square with dollrod in it to hold the disk. These slide in and out of a dado in the side of the case. It can also allow you to take the whole tray to where you are sanding. Then mark it by grit.
