OT: Gluing Porcelain
David Hammond, in Powder Springs GA
>I've got a busted teapot lid, in some old blue and white porcelain. What can I use to repair it? It's about 2 1/2" in diameter, slightly domed with a knob on top, and it's a clean, straight break - about one third of the lid broke off, on one side of the knob.
I've got West System Epoxy, Poly Glue, CA, etc, but I wasn't sure what would hold up to the heat of a teapot lid...
Thanks,
David
Re: OT: Gluing Porcelain
Keith Newton
>CA would be my choice, Now the choice of viscosity would depend on the nature of the break. #2 may be the easiest to control, because it is not so runny.
Some parts, you can just forget about clamping, for those it is great to have a glue like this that will set fast enough while you hold the parts in position with your fingers.
Mark Kauder, Phenix City, AL
>David,
I have used CA w/o problem on tea cups, etc. I would worry more about the moisture than the heat.
Mark
>Good Morning David,
I concur with CA glue as the choice. Regarding heat, I use it to fix broken pipes where the stem joins the bowl. Its been a permanent fix--for years in a couple cases.
George
>Thanks folks! CA it is then; I just hope I have some medium viscosity, 'cause thin is all I remember seeing in my shop...
Thanks again,
David
Great fix!
>Thanks again guys; the CA did the trick no problem - good as new!
David
