Milk paint advice
Milk paint advice
Milk paint advice
Lee.............
>I really like the look of the milk paint finishes, and I'm gearing up for my first attempt. I'm building a few shaker style dry sink cabinets
and I think they will look great with the milk paint.
My first question is what prep does the wood( and a little ply-wood) need?
My wife wants to paint a few flowers etc over the milk paint, any advice?
what about color combinations? I've seen various colors used together to create more 'depth'.
Any advice you have for someone trying this for the first time would be very appreciated. If there are any pics you would like to share please do!!
Thanks Lee
Re: Milk paint advice
John in New Mexico
>Hi Lee,
No special prep is needed, just paint it over raw wood. It will raise the grain, so steel wool or light sanding after the first coat is a good idea. The paint itself tends to be gritty, I've heard of thinning it down by half and doing twice as many coats to reduce the grit. In the past I've just done a careful sanding after the first coat, and steel wool after following coats (three or four total for me). Painting over the milk paint is no problem as it's pretty porous and will give a good adhesion surface. I'd probably do that before oiling, as if she uses an acrylic paint it might not stick to the oiled milk paint. I believe the oil is considered optional anyway, but I always do it. Usually thinned tung oil or multiple coats of waterlox.
John
>On the one chair (and five shaker boxes) that I've done, I raised the grain first with a water "wipe" followed by sanding. That way it didn't get too fuzzy from the milk paint.
Re: Milk paint advice *LINK*
Paul in MA
>Lee,
It's about as easy as it gets. The other responses pretty much sum it up. I wouldn't thin the paint much if at all. Don't shake it as it gets very frothy. Stir until smooth, then just paint. Two coats definitely are recommended, sanding (320 gr or so) between coats Regarding color combinations, if it's a Shaker piece, its best to keep to Shaker colors. A little research helps here, but most utility pieces were red, or yellow. Green was for beds, and blue for meeting house (religious) uses. I've had good luck "aging" pieces by painting with one color, then another, then during the distressing stage I sand through the top coat. Experiment, and remember that oiling drastically changes the appearance and color. Good luck.
BTW, if you want to see some of the pieces I've done, click the link below. (site is under construction - look in tables, chests, etc)
Shaker furniture
I hate the stuff
bill tindal, E.TN
>It settles while using it, it rots quickly if you try to store it, it takes practice to get it on uniformly and of desired strength.
I find the Country Colors paint (available Woodcraft and elsewhere) looks very similar to the milk paint and by comparison a joy to use.
