Rabbet cuts
Rabbet cuts
Rabbet cuts
Don Evans
>Hi all:
Being inexperienced with routers I have run into the following problem and would like to know what you think is causing it.
The set up: 1/2" rabbet bit, rabbet in back of molding is 3/8" x 3/8". I set the fence (per books on the subject) so the bit would take the full 3/8" portion of the cut INTO the wood and brought the bit up in 4 different passes to get the other 3/8".
The problem is chip out just ABOVE the cut where the bit exits the wood. This of course is on part that will show and therefore must be corrected.
The project will be black lacquer finish so I am making the molding from poplar. The pieces I have for the molding are straight grain with no limb or knotting.
The bit is new, first cutting it's done.
One last comment, the chipping seem to occur on all 4 passes not just the last one.
Any suggestions in how to stop it from chipping away wood above the rabbet?
Don
Re: Rabbet cuts
Re: Rabbet cuts
Doug in Denver
>Try the exact opposite of what you are doing. Raise the bit to full height, but only cut the depth into board a little at a time. That's how I would do it in chippy wood. On the firt pass, cut very shallow. 1/16" or so.
Re: Rabbet cuts
Two options
Lee Schierer, McKean, PA
>One way to eliminate the chip out is to raise the bit tot he full height and make a shallow cut, say 1/16" deep int the side of the piece where you want the rabbet.
Another way is to raise the bit to full height and make a shallow 1/32"-1/16" deep cut doing a climb cut. Be careful doing this as it will tend to pull the board into the cutter so have a good grip on the part as you feed it through.
One other option is to make the first cut on a table saw and just use the router to clean out the rest of the wood.
What is occuring is that your cutter is trying to lift the grain and the grain is tearing out (Oak is particularly prone to dooing this). By climb cutting the cutter will be pushing into the wood rather than pulling out so the grain will get chopped off. Because of the way the grain runs in the boards, some pieces will have more tear out than others. Some boards will have grain reversal in several areas .
Lee
Re: Rabbet cuts
Thanks for the help
Don Evans
