I'm planning my son's bunk beds, and must decide how to attach the rails to the head/foot boards. I've been looking at the FWW issue 175 (Feb 2005), which deals with the subject of bed design. I've been leaning 'tword the bed bolt option, and want to hide it in the rail, with the nut inserted into the head/foot rail. My questions are:
The design shown in FWW has the head/foot rail mortised into the post with a nut inserted into it. The side rail had a groove into which the bolt is placed, but it does not have a tennon. It is only inserted into the post with two dowels, then the bed bolt goint into the post. Is this strong enough?
If it isn't the best way to go, what is? I could, I suppose, use the more "traditional" way, and use a bed bolt cover of some type, but I'd like to avoid this if possible.
The last bed I made, I used the brackets. But, being a bunk bed, I'd like to make it a bit more sound.
Thanks, and I look forward to seeing your thoughts on this.
>Can't comment on the FWW design question, but I built a double sized Bunk bed out of cedar planks and 4x4's for our sleeping cabin at the cottage and went through many of the same questions about strength.
I had always used brackets before on beds, but this time I was not prepared to wonder about the strength and durability.(especially seeing as I am one of the people sleeping on the bottom!)
Our kids sleep on the top, and like all Kids they jump around,play around despite being told not too,so I over spec'd for peace of mind.
I used longish mortise and tenons to join the upper and lower side rails into the head and foot assemblies, and drove two long heavy gauge lag bolts through the face posts of the head and foot boards into each tenon. Overkill? Maybe.
For the cottage I was not really worried about hiding the lag bolts so they are just recessed.
I just couldn't rely on the bolts alone which I think are really designed to keep the pieces together, not take the pounding from any jumping around.
>I recently built a bed of walnut for my son. Did not want the bolts to show and wanted a really solid connection. My "mistake" was that I had already laminated the posts.
What I did was buy a 3/4: steel rod at the borg. Drilled holes through it and tapped it for 3/8" bolts. Cut them two inches long with the holes in the center. (barrel bolts or rod nuts, you can buy small ones, but I could not find larger ones.)
I drilled into the sides of the posts for the barrel bolts.
For the rails, I laminated them out of two pieces of 3/4" stock. In the inner piece, I cut a Tee shaped slot. The head of the Tee allows you to turn the wrench. The leg of the tee allows you to insert the bolt. I cut a filler for the leg of the Tee, because I wanted the bolts to be "captive" but removable and replaceable. (my son would lose them) I put a magnet in the end of the filler block to hold the bolts "retracted when the bed was disassembled.
I used a half inch core bit in a router and routed a half round groove in the inner and outer rail laminations for the bolt to slide through.
I cut a half inch long by quarter inch deep rabbet on each side of the rails, reducing them to 1" thick on the ends. Cut a matching mortise in the posts. So I my case, everything had to be centered. Mortises centered in the posts and holes centered in the mortises.
I drilled through the bottom of the mortises into the post and past the point where the barrel bolt would be to allow a "pocket" for the tip of the bolt.
I have tried a picture of a mock up. (very crude) The walnut piece shows the cuts in the rail. The pine 2x4 shows a hole in the edge for the barrel bolt and there is a barrel bolt in the picture.
To make sure they would work, I use half inch bolts wrapped in thin plastic to force the two have of the rails to line up. That hole was half inch, but the actual bolts were 3/8. I epoxied the barrel bolts into the holes to be sure they did not float out of position. I actually assembled each joint with the epoxy in place and let them cure to be sure all was aligned. then I plugged the holes with turned walnut plugs.
When the bed was finished and assembled it was solid. Really solid. I am really glad I did not use brackets or hangers. I routed a storage place in one rail for the wrench. Magnets again.
If you are laminating the posts and can get ahead of the curve you could make recesses in the posts and build in washers and nuts. You would have to be absolutely sure you kept up with them. If you trimmed a post wrong, they would get out of position.
>I did the rails traditionally with M&T and bed bolts. When assembled you can not even slightly flex the bed, just what I hoped for. Some different than wiggly store bought bunk beds. I did another loft bed with 5' legs and it doesn't flex either, in spite of a 5' leg.
