Jointing wide boards
Ken Krawford
>I have an 8" jointer and need to surface some rough sawn boards that are 12" wide. Is there a way to do this on my machine?
Re: Jointing wide boards
Ells in Boulder
>Hi Ken,
Check out my post of about a week ago on the "planer sled". Can't say enough about it, works like a champ for what you are asking about. I think you'll get mostly a negative response to trying the wider boards on a jointer.
Ells
MaxM
>Buy, rent or borrow a surface planer. I bought 20' of 8/4 x 10" rough sawn Rock Maple for a cutting board. I joined one edge on my jointer, resurfaced top and bottom through the planer, and ripped the final side on the tablesaw.
You will always find uses for the planer. I have the 12 1/2" Delta w/locking cutterhead.
Planer sled!
Mac in Indy
>The proper use of a planer sled will give you the flat face you need to then plane the other side parallel and get a flat four square board. Or you could go out and buy a 12" Jointer!
MAc
I do it all the time...
John in New Mexico
>The only drawbacks are 1. the guard has to come off, and 2. you need a little extra thickness.
Flip the board end for end every pass so you get as even a cut as possible, and take really light cuts (like about 1/32 to 1/16) as tear out can be a problem going against the grain every other pass. Slow feed helps too.
When done, you'll have a face with any humps and twist removed that you can use to plane the other face. Once the other face is planed flat, you can flip the board over to remove the slight rabbet left from jointing.
You should be able to do up to a 13" or 14" board on an 8" jointer, but it may take a little practice.
John
It's doable
Denis Ch�nard, Orl�ans, Ont.
>Warning: this involves removing the guard. Don't do it if you're not comfortable with that.
Take the guard off, set the jointer for maximum width of cut, and joint away. The part that doesn't get touched will just hang out, in effect you're making a 8" wide rabbet. Once the part being jointed is flat, take a power planer (or a hand plane) and take down the part that hasn't been touched yet even with the jointed part. Plane the other side, then do one last pass on the first side to clean it up. Works great.
DC
Don't forget to put the guard back on the jointer afterwards! :-)
Mark McC
>FWW had an article on jointer techniques while back and this was one of the topics.
As the others have said you have to remove your guard, but then you should install a new "homemade" guard which is just two pieces of scrap wood each 5 inches wide and screwed together at 90 degress. One maybe 8 inches long the other maybe 3inches long.
Clamp this "right angle assembly" onto your fence with the 8" long end centred directly over your cutterheads and slightly higher off the table then the boards are thick.
This will identify the cutterhead area while your jointing and be wide enough to keep you fingers from getting to close to them.
The other part of this wide board technique is to use a sharp block plane to take that small rabbet left from the part of the board that hangs outside the cutterheads. Guess that depends how wide the boards are versus your jointer bed. Everytime I have done it its been manageable to use a plane rather then try to re adjust or take super light cuts to get rid of the rabbet.
Worked great for me and can be done safely with the usual amount of care and a homemade temporary guard.
Kneale Brownson in Northern MI
>If you don't have one face of any width board jointed flat, you run the risk the planer will leave you with a board that's the same thickness through its length but wavey. You need a sled that can mimic a jointed surface to be certain a planer will give you reliably flat finished boards if you can't joint one face first.
