>Everytime I rip a board I get a cut that is slightly concave (about 1/32). I tried aligning the blade and even played with the fence but no matter what the cuts keep wandering inward. I don't really have the problem with crosscuts, only ripping. Does anybody have any experience or insight they could share to help resolve this?
>I have that problem with my Craftsman 22114. It has the aluminum fence, and it deflects approx 3/64" unless I clamp the back end to the rail. Try this to check yours...Lock the fence in place right in line with an edge of the miter gauge slot, and put two fingers on the back end of the fence. Then pull your fingers toward your hand as if pulling on a rubber band. Then look at the fence and see if you can see the edge of the miter slot anywhere along the length of the fence. If you can see it, then your fence is deflecting, which will cause the concave cut you describe. It does this because as we start our cut we are mainly interested in starting straight, then we push against the fence in the middle of the cut, and as we near the end we are pushing straight again, and our left hand is readying to move the offcut out of the way, not pushing against the fence.
By clamping the back end of the fence, you eiminate the "give" during the cut. Having said that, I am only going to deal with that for a bit longer...Biesemeyer here I come!
>I agree with Stuart. How to fix the problem? You may want to think about getting a new fence eventually. I had a sacrificial fence added to my fence for a project. When I ripped a piece without taking the sacrficial fence off, I didn't have the problem. Presumably it gave it enough stiffness to resist the mid point deflection. Just a thought...
>I experience the same thing on my old Craftsmand, but I have a Vega fence on it. I can't imagine it deflects in the center, but I'll check.
I wonder if this is something that a better cutting technique can also solve, along with the information below about a clean blade and surface and fence.
>If your cut is concave, and it's not the result of the board bowing to relieve stress, to me that says that it is leaving the fence during the cut, which could be a fence and/or blade alignment problem. A saw blade wants to track itself straight through the cut, and if the fence runs away to the right, the board you're ripping will tend to go straight instead of following the fence. So, it pulls away from the fence, perhaps imperceptably, and you get a concave cut.
If the fence is aligned properly with the miter gauge slot, it could be that your blade is slightly out of alignment, heeling to the left slightly at the rear. You can check it with a simple test that doesn't require a dial indicator or a reference plate. Raise the blade all the way and, using your miter gauge, cross cut a piece of thin scrap. Without releasing your grip on the piece, slide the miter gauge back and forth a couple times between the back teeth and the front teeth. The ticking sound should be identical. If it is not, your blade is probably slightly out of alignment with the table top. If so, and you need some help aligning it, let us know.
