You were right!
Robby Wright in San Marcos, CA
>I have been building a bass guitar body and bought a piece of flamed Tamarind for the top. I needed to resaw the piece so I could bookmatch it. I have been dreading doing this task, as my previous tries with a Timberwolf resaw blade were less than ideal.
While I was in Atlanta last year, I stopped by Highland Hardware and bought a couple of their Woodslicer blades. For this adventure, I mounted it on my 14" Jet with a riser block and retrofit Carter guides. I set everything up with the new blade and was ready to go.
I made a test cut to check blade drift and surprise! There wasn't any. So I clamped my resaw fence to the table, turned the saw on and started to feed wood to the blade. I couldn't believe the difference! The Woodslicer went through the wood like a hot knife through butter - cut speed was at least double the Timberwolf blade. There is very little ripple, no barreling, and I will just have to lightly touch the wood up with a sander before before gluing the top to the body.
Having experienced both blades, I can now highly recommend the Woodslicer. Thanks for the tip!
Robby Wright
