Source for ABS Sheeting?
Mark Kauder, Phenix City, AL
>I am planning on rebuilding the cover for my Proforax 16-32 with a 4" DC connector, and I need a source for ABS plasic to make it.
Anyone know of a source?
Mark
Re: Source for ABS Sheeting?
Keith Newton
>I spent a year away from my long woodworking career supervising a plastic shop. This is the supplier that we used most.
http://www.copeplastics.com/docs/products.htm
Ed Mulligan, Cape Cod
>Mark -
I've heard that the newer version has a 4" dust port and that the new lid will fit older machines with minor work.
Ed
>I just got off the phone with Performax Tech support, and they say that the assembly is different and they even claimed that I would need a new head assembly. My guess is that if I bought just the top door of a new one that I could make it work. I think I will put out a call on the boards to see if someone has the part number and go from there.
I appreciate the information.
Mark
Performax 16-32 Part Number anyone?
>I am looking for the part number for the new DC cover with a 4" port that I hear is on the newer perforax drum sanders.
Anyone?
Mark
Re: Performax 16-32 Part Number anyone?
>Mark -
I DLed the owners manual which has a parts list in the back. The part number is 80-2002. The machine is model 629004k.
Dust collection works well on my 16-32 with the 2" (?) dust port but I'd like to switch to a 4" port because it would be easier to hook up to my dust collector. Let me know how it works out for you.
Ed
>Ed,
Thanks much for the part number.
I found that the 2" port worked fine if I was using a vacuum, and just sanding small parts (normal for me), but with a DC, it was leaving dust on the conveyer belt.
Mark
>Mark, I posted a question two or three weeks ago about swaping the new four inch hood for the old two inch one. Two or three people came back and said they had done it with minimal work. Last time I was at WoodCraft I scoped out the new machines and could not make the decision. I think I will take the hood off mine to the store next time I think about it.
>Barry,
I emailed Performax and asked for a price on the 4" hood. I will post the information when they answer, and email you.
Other than the DC connection difference is, that the 2" model hood is attached by a couple of piano hinges, and the 4" model is attached by half hinges on the hood, and half hinges on the sanding head, both connected by hinge pins. Does not seem like like a tough conversion.
If it is too much $$, I already have an ABS floor sweep that I can cut and manipulate to fix the current hood.
Mark
Art Liebeskind
>Hey Mark,
I just added a 2" to 4" adapter and my system picks up ALL the dust. Why work so hard?
Art Liebeskind
>Art,
I am using an adapter. Might just be my system.
Mark
>I could enjoy my woodworking a lot more if I did not have to work a real job to support the habit. I woudl appreciate the price fo the hood. Just another detail I ahve not managed to find time to track down.
I too use a four to two reducer.
As an aside, I was fiddiling with my DC trying to improve performance. I have a Delta unit that is supposed to provide aobut 1300 CFM (1 1/2hp). I usually just shake the bag rather violetly after I put the fresh trash bag on. It happened that I took the cloth bag off the unit and turned it inside out and shook it out. It was a stunning dust exploasion. Best to to it outdoors and under an assumed name. Run away fast. But, it made a huge difference in the air flow in the system. I had not done this since the system was new a year or two ago. Apparently the bag had gotton clogged.
I really did not shack it much, I was in a hurry and was so surprized by the amount of dust. If you have a filter bag I woudl suggest you take it out side and shake it out thouroughly.
>Here is the response I got from WMH Tool Group:
Hi Mark,
Thanks for your e-mail. This dust cover is in stock and costs $8.43. Replacement parts can be ordered directly from our Customer Service Department by calling 800-274-6848.
Please let me know if I can be of further assistance.
Aundrea Berkey
Internet Customer Support
WMH Tool Group
Makers of POWERMATIC�, JET�, and WILTON� products
Cheap at twice the cost in my opinion. I bet shipping is at least that much.
Mark
$8.43 .... Wow,,,,,I was expecting .....
>four times that, literally. For 8 or 9 bucks I'll take a whack at it. I bet you would be hard pressed to buy the ABS for that. And the time would take has got to be worth a couple of bucks. That's actually unbelievable. Order one and then tell us what the trick is. Fifty seven bucks shipping I bet.
Re: $8.43 .... Wow,,,,,I was expecting .....
>I concur on the pricing/cost thoughts, Barry.
I did order one. Total was just under $15 with ground shipping from Knoxville, TN.
If it went out today, I should have it Friday, first of the week at the latest. I will take pictures and let you all know about the install.
Mark
Re: Performax 4" Dust Hood Conversion
>Well Folks, the Perforax Dust Hood with the 4" connector came today. And to say that the conversion was easy would be understatement. Even with a couple of mistakes on my part, I am sure that it did not take 20 minutes.
I did not photograpically record the whole process because it was so easy from the start, I figured if you need that to figure it out, you are a danger in any shop, using any tool. ;>}}}
This is the method I used - I will suggest another couple options at the end:
1) Remove the old hood with a straight blade screwdriver and a 7/16" wrench. Leave the old hinge in place for now.
2) The new model hood has 1/2 of the hinge system molded into the plastic. You need to remove them. I used my bandsaw, and then sanded it smooth.
3) Place the new hood in place, and mark, through the screw holes, the location to drill the screw holes in the hood. Drill the new holes.
4) Remove the hinges from the inside of the sander. Mount them in the same location, but on the outside of the sander. To do this, you need to cut a couple of slots in the bottom of the hinge to clear the casting webs on the top sanding head.
5) Take the handle and latch off the old hood and attach them to the new hood after drilling holes in the appropriate location - measure carefully, the latch has a realitively small range of adjustment.
6) Done.
Now for a couple of other options:
1) When I drilled the holes for the hinge, and saw that it would leave a gap at the back of the hood. You could leave the hinge in the original position, and just add a bit of rubber gasket to fill the gap.
2) Another option is to leave the hinge in the original position, but remove the appropriate material from the new hood to clear the piano hinge. I could still use this option, but what I have works, and I do not care about the hinges being on the outside.
Mark
Thanks for the follow-up
>I'm ordering a new hood tomorrow!
Ed
Re: Has something changed?
Kirk (KC) Constable
>The 2-1/2" or whatever came on my several year old 16/32 has never caused any problems. Is the upgrade really necessary?
KC
>Kirk -
I hook my 16-32 to a 2 h.p. cyclone. It collects dust very well - approaching 100%. I'm going to switch to the 4" port to eliminate most of the reducers I have to insert upstream from the sander. For me the upgrade was a very low priority task but when Mark discovered how cheap and easy it is to convert, I decided to do it.
Ed
>I think the main problem for me was based on some of the sanding I do.
When I sand flat pieces of wood, I had no problems, However when I sanded segmented rings for my bowls, dust would remain in the open center of the rings, and then fall of the conveyor belt onto the floor. I think that the reduced suction on the 2.5" (conpared to the 4") was unable to overcome the turbulance in the sander.
It is quieter too.
Mark
Kirk (KC) Constable
>That makes sense. Thanks for the comeback.
KC
