How Wide is too Wide for Cabinet Door
Howard G
>I have a customer who needs an entertainment center, the center unit being 60" wide. He only wants 2 doors that after trim would likely be 27" wide. The wood is pine. I am concerned that this is too wide a door, but he asked me to try and work only two doors into the design. What are your opinions on this? Thanks for your help.
Re: How Wide is too Wide for Cabinet Door
>Good Morning Howard,
The size of the door may be influenced by the size of the space it opens into. I had much the same dilemma when I designed our corner china cabinet. A single door would have meant the evacuation of dinner guests every time we opened the door.
Suggest two bi-fold doors as a compromise. He'll get his two door units, and have a smaller projection into the room.
George
David Hay @ Denver
>I guess one thing that might influence the decision is whether this is a solid wood door or frame and panel? If it's solid wood, I'd worry about warping and expansion and contraction interfering with the gap between the doors.
Also, will the doors slide back into or fold back along the sides of the cabinet once they are open? If not, they'll be projecting pretty far into the room or off to the side.
David
Ted Wong
>I would probably find some way to break up the scale of the doors. you can do this by adding details like multiple panels or reveals of some sort. I've never built an entertainment center but I have done other fairly large pieces and I've found that big expanses of cabinets with big doors can often create an overwhelming sense of proportion. This of course is dependent also on the size of the room. If you have tall ceilings and a generous area then large doors may be in scale with the room.
Re: I read what the others said
Glenn Madsen near San Francisco
>and you might be OK to build him a frame and panel door at that width. Yes, it will extend somewhat. And you will have to allow for the structure to be solid.
But an entertainment center usually doesn't have someone sitting 36" away. It's seldom in a kitchen or dining room, with cramped pathways and busy people with dinner, dishes and expectations weighing them down. It sits in a bedroom, a den, a parlor or a living room, and folks sit back and watch.
I'd let him know about the structural issues, and build a quick mockup, if the funds allow. Don't scrimp in the hardware specs. Use enough, and good enough, hardware.
Robin Corell in Atascadero, CA
>I would be curious to know why the client has decided they only want two doors. Is that decision based on knowing all the available options? The proportions of doors that size are very likely not going to be pleasing or balanced. I would be hesitant to build something that I thought was going to be ugly or ungainly in its proportions. These projects for me have not been pleasant to work on and many times the client is not as pleased with the end result as if I assert my design expertise and offer a solution that is a good design and meets their requirements of function.
To offer a different approach on how to make the requested doors I would probably opt to make them like a hollow core door, basically a thin torsion box, and then add applied trim to make them look like frame and panel construction. This same method can be used to make them as bifold doors and have the applied trim simulate a single frame and panel door. This way the client gets the look of a single door and the functional qualities of a bifold.
Robin Corell
another alternative
Bruce, a MN Galoot
>you could also try tambours.
Bruce
Howard G
>Thanks everyone for the great comments. I put two 26" wide doors into the design and I'm waiting to get feedback from the customer. I also incorporated the suggestion from several of you to divide each door to give the impression it is 2 doors. Thanks again.
