REAL MILK PAINT
OT: Computer Image Question - Reprise
Robert Hutchins
>Thanks to all the kind, generous folks here, I now have the wherewithal to image my hard drive. I plan to write the image to an external USB HD, but I got to wondering if it could be put on a thumb drive.
Anybody ever done this?
TIA
Re: OT: Computer Image Question - Reprise
Ron in Drums PA
>Depends how big the thumb drive is and how small the hard drive image is. If it fits, yes you can.
THats would have to be a pretty darn big thumb....
>Hmmmmm.... how BIG is your thumb?
If I understand correctly you're talkign about putting the "image" file on a USB drive, right? And then transfering the "image" to a internal drive, right? You're not planning on trying to run the OS from an external drive?
You can infact copy the image to any device you need, assuming the imaging software can handle it. Typically we've Ghost and CDs for small OS only images (like W2K) and DVD's, and successfully used USB drives with no problems. And if the thumb drive was large enough you could certainly use that. Flash memory thumb drives are 2GB and 4GB these days. But at that size they're not inexpensive.
Happy Woodworking!
Re: THats would have to be a pretty darn big thumb  *LINK*
Ron in Drums PA
4Gig
Bought a 2GB Thumb for $25 today.
Robert Hutchins
>Thanks, guys.
I'm trying to rethink my strategies for resilience on my system. My hallucination about RAID5 the other day was based on the appeal of the simplicity of recovering from a drive failure. Why can't I have channel speeds for I/O like I used have on mainframes for next to nothing on my PC? (rhetorical).
Seriously, I'm thinking of putting just my OS and core, high value programs on one HD and splitting up other software and data files on other HD's. I was thinking of using a 5GB thumb to hold the image of the OS and HV programs HD, while using a combination of CD's, external USB HD's, and thumb drives for other software and data. I'm still pondering the imponderables, here. I don't know whether I'm willing to go to the trouble of classifying everything and trying to keep up with it. I am convinced, however, that putting everything on HD's without any strategy is a recipe for disaster.
Thanks for you help.
Tom
>Both Symantec and Acronis will let you choose from 3 different compression schemes when creating the image, iirc. It all depends on how small you can make it and how big the drive is. You also have to make sure that whichever you use will recognize a usb drive. I just use an old ide hard drive. It only takes 2 minutes to open the case and attach it to the ide cable.
Loyd Lucas
>With the price of hard drives today, when I built this computer I'm on now I bought two 80GB hard drives and I simply image the primary to the secondary and then disconnect the secondary to protect the image on it.
Robert Hutchins
>Hi Lloyd!
I have three internal HD's and an external USB HD and 3 thumb drives. I just HATE having capacity that I don't use (grin). Seriously, I don't see having to image a fourth of a terabyte as being efficient, that is, if you image as frequently as one should to protect his OS and core programs. Data - well there are lots of strategies for data.
Saw an 8GB thumb drive for $90 from tigerdirect the other day. Wonder how long it'll be before they're $25 like the 2GB ones are today?
Protect yourself from yourself
>"... I just HATE having capacity that I don't use..."
Easy solution, not only should you backup to an external source to protect against data lose due to hardware failure or localized disaster, but it's a good idea to have generational copies to protect yourself from yourself.
You know... your go into a document, make changes, forget to do a save as, overwrite the original that you needed to keep..... and you don't notice your mistake for 7 weeks.
If you keep extra (weekly or monthly) backups of your data like BACKUP1, BACKUP2, BACKUP3, BACKUP4, BACKUP5, BACKUP6, etc. Not only will you protect yourself from your own flubs, but you'll quickly use alot of diskspace and no longer have too much excess unused disk space.
Since a generational backup is not to protect against hardware fialure, etc. you can keep those on a internal drives.
But you probably already know all this.
Backup strategy is about complimentary solutions that protect from all sorts of failures, both mechanical and human.
Happy Woodworking!
