wood movement
wood movement
wood movement
scottco
>I am making a toy box that is basically a blanket chest. I want to use solid wood for the sides and bottom, but I am worried about the wood movement. Can I just run a groove in the bottom of the case? What is the best method to attach the bottom?
Thanks in advance
Re: wood movement
Re: wood movement *LINK*
>As is often the case, It Depends.
What wood are you using and how dry is it?
Are you building a "five" board box? Four boards horizontal, forming a rectangle and the fifth board for the bottom? (These "boards" could be glued up panels of solid wood, the issues would remain similar.) There are on line calculators that will allow you to figure out the change in width of the board, based on the species of wood and the expected change in moisture content, and the width.
The short answer is YES, but you would have to make the grooves deep enough to allow for the movement. The simplest thing might be to make the bottom out of plywood and that would dramatically reduce the problems.
The Shrinkulator
Re: wood movement
Re: wood movement
scottco
>This is a "five" board box made from soild Cherry that was kiln dried. Unfortunately, I hate plywood,and I would like to use hardwood for the bottom as well. Any other suggestions on what can be done? I have already glued up and sanded the bottom panel.
Re: wood movement
Re: wood movement
Robin Corell in Atascadero, CA
>I don't use plywood either. For bottoms, back panels and sometimes even for shelves I make a rail and stile frame with a floating panel. rather than a typical raised panel detail I leave a 1/16" or 1/8" reveal on all sides of the panel. I calculate the amount of seasonal change for the species and the size of the panel and make my allowances. depending on the size I usually end up with two or three floating panels. for bottoms I like a bridal joint for the frame rather than cope and stick. The amount of shrinkage for the rail and stile members is usually pretty minimal.
Robin Corell
Re: wood movement
Re: wood movement
James Dillon in MD
>Scott,
As others have said, there shouldn't be any real problem with using hardwood for the floor of your toy chest. Just allow enough room for expansion (~1/4 inch total?) of the floor. If you are using 3/4 inch stock for the sides, you will have plenty of room to cut the dado/groove. You might consider pegging the floor in the middle at both ends to hold the floor in place and still allow for expansion. To prevent any potential vibration (caused by too wide of a dado/groove), you could place some rubber spacers in the groove on the long side of the box; just be sure to allow enough room for the spacers when you cut the grooves, DAMHIKT. Good luck.
Jim
Re: wood movement
Lee Grindinger
Grain orientation?
Lee Grindinger
>Is the grain vertical or horizontal in your sides?
Lee
Re: wood movement
Re: Grain orientation?
scottco
>The end grain of the bottom would connect to each side. The box grain runs horiztontal.
Re: wood movement
Lee Grindinger
Well then,
Lee Grindinger
>Glue the bottom in only in the center 2 or 3 inches of the ends. Leave enough space in the groove (Yes, it's a groove because it runs parallel with the grain, a dado runs perpendicular) in the sides for expansion, say an eighth or 3/16". Glueing the bottom to the ends will help with strength in the entire box even though it's only two or three inches.
Lee
