Need Instruction Manual
Mike Jurnigan in Suffolk
>Below is a picture of jig for routing hings for doors and jambs. I have had it for years but I acquired it with out any instructions.
Does anybody have the instructions for this rig or know how to use and set up. I have a set of french doors that I will need to replace the hinge jambs on for a friend. I have not been able to locate a manufacturer or model number on it. When I acquired it it came with what appears to be a 50's vintage Stanley Router set that looked like it was set up for doors. The router motor could be removed from its base and be used to power a plane for planing doors.
Thanks in advance,
Mike in Suffolk
Re: Need Instruction Manual
Off the wall suggestion.
Rod Peterson -- Ormond Beach
>I wonder if Stanley marketed it?
It certainly doesn't look like the modern Porter-Cable or Bosch, but I wouldn't discount it being an old Rockwell (P-C predecessor), either. It's a stretch, but the Porter-Cable website for manuals (euphemistically named by parent B&D as ServiceNET) may be a resource.
Good luck in your quest.
Rod
Re: Off the wall suggestion.
Bruce, a MN Galoot
>My dad had one, and somewhere it's lurking in my grandma's garage. It was made by Stanley, and it was part of the kit that came with the router and plane attachment. He got it back in the 50's.
It's really not hard to figure out. IIRC, the jig is nailed to the door, using the integral nails (pegs, whatever) and then the mortises are routed. Remove the jig and attach it to the jamb. Repeat. It worked pretty well, and made hanging doors a snap when set up right, because the spacing between hinges on both doors and jambs will be identical.
The router, OTOH, was a bit of a PITA, because it had a collet that liked to jam up, and the shaft lock is a button that you push in on the end of the shaft, on top of the motor. That lock wore down over time and it can't be replaced because the parts aren't made anymore.
Bruce, who appears to be dating himself a bit...
DaveK
>I Have a stanley that's over 30 years old and a Bosch (who bought stanley out) and neither look like that. If it was stanley it would have to be over 40 years old. As i have used them since 1972. does it have any writing on it at all
>None that I could find.
Mike in Suffolk, Va
