pella windows
Dan Arrowsmith
>I need some guidance on pella windows as I have to replace some. As I understand it when you buy double glazing windows the space between the panes is sealed. With the pella windows I have, you can pull out one of the panes to clean the glass, it is held in place by little clips. Some of these windows have condensation between the glass and some have condensation on the house side of the glass. The condensation has been there for a while as the inside sill and frame has started to rot. With the windows that have the condensation between the glass I tried to ensure a seal by adding cauking strip between the wood frame and the rubber suround of the glass, but didnt see any improvement. any suggestions, I know I need to replace the bay window and check for rot underneath but I dont want to buy the same problem again. Thanks for any suggestions.
