OT: Redoing phone wiring
wilbur
>I've decided to clean up the phone wiring in my house. There are only three functional phone outlets in the house: one in the kitchen, and two in the basement. There used to be a wired alarm system in the house, so it looks like all the sensors have phone lines running to a junction point where the alarm box is. It looks like the phone service comes into the house, heads over to the nonfunctional alarm junction board, then enters a rat's nest of phone wires. It's just a big mess, and I think this is the cause for the occasional noise problems we have on our phone.
I'd like to scrap the alarm system, and set up a star wiring system for the phone lines. Here are my questions -- hopefully someone can help me out:
1. Is there any advantage between using a 110 or a 66 block?
2. The point at which the phone service enters the house is really old-fashioned. There are 4 screw terminals on the outside of the house, which connect to 4 screw terminals inside the house. I've figured out which pair of terminals provides our phone service. But because of how a lack of color coding on the wires that connect to these terminals, I can't tell which terminal is red, and which is green (or blue and white/blue). Is there a way to figure this out? I do have a multimeter.
Re: OT: Redoing phone wiring
Rod Peterson -- Ormond Beach
>110 vs 66. I don't think it matters. They take different punch-down tools, but the one I have has blades for both. The modular connector series in my system uses 110 for the jacks (although I have a 66 block in my junction box), so that may be a consideration for you.
There is a polarity, but I don't know which (ring or tip) is which. The old, original TouchTone® used to be polarized, so if you hooked it up wrong the tones wouldn't work. I believe all modern equipment works either way now.
The only other thing to watch for is which wiring scheme (EIA 568A or B) to use. With the exception of some specific equipment (do a search to find out) either one will work fine for basic home phone/data, but you need to be consistent and do it one way or the other throughout your system.
Rod
Addy Protocol: I'm not a phone techie (although there are several here)—I basically learned about this stuff on the internet.
Glenn Madsen near San Francisco
>http://cableorganizer.com/phone-data-connection-blocks/
on the wiring blocks. This seems to be pretty good info.
Regarding your rat's nest: If you have time, access, physical flexibility and the right tools and supplies, rewiring your phone system will be a satisfying, but tiring job. Your assumption that the former alarm system is a primary cause of the noise is probably valid. All that wire is acting not unlike an antenna. Getting rid of all of it, replacing with fresh, is what needs to happen. The phone company dosen't do this any more, although a contractor can. The labor isn't free, but the parts aren't terribly costly. The downtime on your phone system will need to be considered, so plan an alternative temporary hookup, or have the office call your cell.
Have fun with this! Mine's all been redone, but my sons did the crawling about under the house.
woodenLeg
>When I had to rewire my house phones, I also added a DSL line. I called the phone company and was there when they installed the new box and I asked lots of questions. I also found out the guy liked homemade jerky. When I was done I called him(he give me his business card) and asked him to check out the system, bribing him with jerky. Everything was fine. Dave
Most people 'round here use 568B
110 v 220
>Ooops... sorry, not 110V vs 220V...... wrong thread.
110 vs 66
66 is pretty much standard for phones, 110 for computers.
110 is a better connection rate for ethernet, 66 isn't.
66 requires a proper punchdown tool. Good quality $70, cheap $30.
110 doesn't requqire an expensive punchdown tool. You can get free plastic ones that seat the wire an dthen use a utility knife to trim it. If you can't get a free plastic one, I'll mail you one. I have hundreds.
66 blocks are cheaper per connection (more fit on a standard full size 66-block), but you can get smaller 110 blocks that are cheaper. You can get half height 66 blocks but they aren't muhc cheaper than full size.
HomeDepot is a good source for low quantity (ie. 1) 66 and 110 blocks. There are places to get it cheaper, but it's only worth it if you're buying large quantities.
Oh, tip/ring? TIP is the white+coloered wire, RING is the solid colored wire. The standard is the white-stripped of a pair goes on top (on a 66-block).
So from top to bottom it:
White/Blue
Blue
White/Orange
Orange
White/Green
Green
White/Brown
Brown
well that's for 66 blocks which are not color labeled. Many 110 blocks are color labeled.
IF you are mixing old red/black/green/yellow cable with the newer blue/orange/green/brown cable, here's the conversion:
WHITE/Blue > GREEN
BLUE > RED
WHITE/orange > BLACK
ORANGE > YELLOW
Oh, and pickup a $3 phone tester at HD. It will light up green if yuo've got the wires right, red if the TIP/RING polarity is reversed. Oh, and the LED won't light at all if the line is dead. This is more reliable than a multi-meter.
Oh, and to test which lien is which (in a multi-number home) you need a $150 "butt-set" or just use a regular $10 phone and dial your cell phone ;)
Happy Woodworking!
Figured it out
wilbur
>Thanks to Rod's mention of polarity, I found out that under normal circumstances the tip (green, or white/blue) is at 0 V, and the ring (red, or blue, or blue/white) is at -48 V. So all I had to do was go to the pair of screw terminals that I knew carried my phone service, set my multimeter in DC voltage mode, and figure out how to hook up the test leads so that my multimeter read close to -48V. With that reading, my COM lead is on the tip and my V lead is on the ring.
Of course, now that I've sorted this out, I've found that there is another wire hooked up to the other pair of screw terminals, which should be my black/yellow (or white/orange and orange) and those wires are a pair of white/blue and blue wires. The white/orange and orange pair of wires aren't attached to anything.
I'm REALLY glad that I am redoing this from scratch.
Since this is going to be a voice only hookup, I'm going with a 66 block. Actually, tonight I found that there is a mini 66 block hanging out in the rafters of my basement, with some lines hooked into it. Of course, this block doesn't seem to connect with the rat's nest of my existing phone system. But it should give me all the lines I need.
