Wipe On Finish
Seth Honeyman
>I've just applied three coats of Watco Wipe On Poly (one per day) to a rolling tool cabinet I built. How long should I allow the final coat to dry before I rub it out and wax it?
Thanks for your help - Seth
Wipe On Finish
Seth Honeyman
temperature a big factor
bill tindal, E.TN
>There is a huge difference in curing rate with temperature. In the hot of summer I would say a couple of days would be adequate, if not sooner. You might be able to test hardness with a finger nail imprint on an inconspicuous place.
Two days
Michael Dresdner
>If you wiped each coat on and off, leaving only the thinnest film remaining, each coat will dry in a day, and you need wait only about two days before rubbing to satin. If you wiped it on as a liquid layer, it could take vastly longer to dry. As Bill said, the thumbnail test will tell you when it is hard and ready to rub.
Re: Two days
markfromsacramento
>Of course, everything depends on the thickness of the finish and the temperature. The best test that I've found is to drag the backs of your fingernails across the finish lightly. It's very easy to tell if it's soft. If you want to know what it should feel like if it's dry simply drag it across a table or desk that has dried for a long time to serve as a baseline.
Re: Wipe On Finish
Jesse in New Mexico
>I would wait at least a week before waxing it.
Re: Wipe On Finish
Seth Honeyman
>Thanks to you all. I did apply it as a true wipe-on (onto cloth and then onto the piece). I used the fingernail test and started the rubbing/waxing process after just about five days. It was ready earlier but snow-shoveling duties intervened.
Regards - Seth
