>i have bought 1500 board feet fo koa wood to make all my bartops and table tops for my new bar/restaurant on the coast in san diego.
i am going crazy trying to figure out how to finsh this wood. i want it to be shown off in all it's natural beauty, but it needs to be able to withstand the abuse a busy bar and restaurant will dole out. any suggestions?
>If you're in the restaurant business, you've probably seen every kind of tabletop finish there is -- from none at all to that poured-on polyester finish that looks about a quarter-inch thick. Needless to say, the thick, glossy stuff will protect the wood from everything but meat cleavers and ice picks, and the clear gloss will allow you to "see" down into the shimmering grain of the koa. You will have to find a local finishing shop that specializes in this kind of coating, though, as it is finicky and a bit hazardous to apply, IIRC.
You may not want to put such an artificial looking finish on the wood though. I can think of three alternatives that are designed to hold up pretty well under the kind of use you expect. One is gym finish, which is a tough, hard varnish used to finish gymnasium floors. Waterlox Coatings used to make a great one; maybe they still do, but there are no doubt others available from commercial paint dealers.
Another option is polyurethane, which comes in oil-based and water-based varieties. I'm told that the water-based brands offer the most abrasion resistance, although I don't know if the difference is quantifiable. There are a couple top-rated brands that are not available at retail; you need to contact a flooring supplier to find out about them.
I'm also familiar with an acid-catalyzed polyvinyl finish that is used extensively in the contract furniture industry for desk tops and work surfaces. Reliant Coatings makes a good one. If you can find a local spray finishing shop that knows how to handle this stuff, it could be a reasonable option. Go for a high sheen to let the beauty of the wood come through.
Also, there are catalyzed lacquers and CAB acrylic coatings available that offer ease of application and a tough, clear finish. Acrylic lacquers are often preferred on light-colored woods because they go on water-white and don't yellow. You don't really need this property on koa, which, if anything, will look better with a slight amber cast.
I think all these coatings will do what you want; sorry I can't recommend one over the other. The key is to put enough of whatever you use on the wood so that it presents an impenetrable film barrier to solvents and abuse. None of these will be easy to repair or refinish in the future, but the lacquers will probably be the least difficult.
>thanks for the advice. i am worried the water based polyurethane finish will chip up, and when that happens, people will start picking at it. does anyone think several coats of a high-quality spar varnish would harden enough and hold up in a bar/restaurant enviroment?
>I don't think that the characteristics of spar make it attractive here. Doesn't need to flex with the changes of seasons (San Diego hardly has seasons). Doesn't need resistance to sunlight, really. And a (relatively) soft surface is going to get beaten up.
I like the Waterlox gym floor option Ellis mentioned.
>It won't resist abrasion and it will be clouded up with fine (and not so fine) scratches in no time. If you want to save some dough and get a nice job, stick with something that can be sprayed instead of brushed.
